[C2] JRS Transverse Spring
I just looked under my 66 roadster and took note of a transverse spring. It is labeled, JRS 21-807. It appears to be manufactured by the "John R Spring" Company. Anyone have information on this company or spring? I'm just beginning to learn more and more about the car.
Transverse spring
Transverse spring. Yes it is the transverse spring company from John r spring. Does anyone know anything about this spring or the spring number?
2023 Restomod of the Year Finalist
No, I haven’t. No info at all on his web site or anywhere else. It appears it’s just another company that manufactures repro Parts. Whether or not it matches an F41 suspension you’ll just have to make the comparison, I’d say it probably does but I don’t know. Try calling them, I’m curious also.
Received 6,943 Likes
2015 C2 of Year Finalist
That looks very unsafe and scary. I would be afraid to drive that
2016 C2 of the Year Finalist
[QUOTE=59BlueSilver;1596327665]I don’t know anything about them, but my recently acquired 65 had his spring also, part # 21-307-219B.
Your spring has no arch left and the way it’s incorrectly mounted probably, I’d guess, makes the car ride like a buckboard. The spacers on the bolts were an attempt to keep the rear of the car from sagging with the flat spring.
I hope that’s on your job list to correct. I bought a JRS spring from CC and it was on my car for only a year before I replaced it. Never could get the ride height correct with it and the car would bottom out on dips in the road. When you buy a new spring, get it from Eaton. Dave
JRS Spring
I'll call the company tomorrow and try to find out a little bit more about their product and Corvette application. My car handles excellently (for what it's worth).
JRS Spring
Is the problem with the JRS spring itself or the installation/placement on the Corvette owned by warrenmj? My JRS spring is installed exactly as depicted in the scan posted by dkleather. Or, is the problem both with the JRS spring and its installation? Just trying to understand the "safety" concern, if any.
My car rides and corners just great and no issue upon acceleration or braking.
Silverrick (01-07-2018)
The pic I posted was from a previous thread and yes, the way it was installed made it ride like a wagon and there was a bad vibration at speed. It has since been installed correctly and no longer have a problem with it. Spring seems okay to me.
