[C2] 1966 Dash Insulation
Can someone give tell where these pieces actual go and the best way to adhere them to the dash/cowl area?
Received 6,928 Likes
2015 C2 of Year Finalist
They go above the the rubber coated insulation on the firewall. I use 3M spray adhesive
USMC 0802 (01-10-2018)
I finally realized to do this job properly (install the insulation) the heater box needs to be remove.
So please talk me through it with the secrets if there are any.
Have my dash painted, new pads installed. Waiting for radio to be returned. Starting to make some progress
Make sure all bolts and nuts are removed. Then take a wide putty knife and gently pry lose. Then re-seal it replace or re-core the heater core. Clean it up, lube the cables and put it back
