[C2] 327 Crankshaft Snout Threads?
Received 1,919 Likes
My '65, which was originally built with an L76 is missing its original block but has many of the external L76 assemblies such as the correct exhaust manifolds and water pump pulley.
It also came with the correct so-called "third design" '62-'65 8" finned SHP harmonic dampener. Since it was installed on a non-solid lifter engine, it was pressed on, and the crankshaft was not threaded for a balancer holding bolt.
I'm slowly assembling a nominal L76 using a correctly dated 327 short block, using as many correct external pieces as I can manage.
My donor short block has a correct small journal 2680 forged crank; however, it too does not have the threaded snout.
I thought, and Colvin's book seems to say, that all '65 SHP solid lifter engines had a threaded crankshaft and employed a harmonic dampener bolt with washer.
Q1: Am I looking at this correctly?
Q2: I'm guessing that I can have the local machine shop drill and tap the crank snout when I give it to them to polish and balance the rotating assembly.
Q3: Anybody know the dimensions of the correct crankshaft snout bolt?
Easiest solution is to pick up a repop bolt from someone like ZIP. Then you have the correct bolt/threads. You'll need the heavy washer and lock washer. Not sure what comes together. If you just need a heavy washer, I have some NOS.
Easy Rhino (01-13-2018)
Received 1,044 Likes
C2 of Year Finalist (appearance mods) 2019
Yes they are threaded from the factory. And yes it is no problem to have yourself or a machine shop drilling thread it. I will check the threads but I believe it is 7/16 fine thread. 7/16 x 20
Broke out the Paragon catalog - part 980K for $10, includes the bolt, lock washer, and hold down washer.
Received 6,937 Likes
2015 C2 of Year Finalist
the same bolt was also used well into the 70's before they went to metric
Easy Rhino (01-14-2018)
Location: Las Vegas - Just stop perpetuating myths please.
If you have your rotating assembly balanced you should include the dampener with the assembly. The dampeners were "tuned" by GM for the motors they mounted on. Mostly for RPM range.
Well balancing is a good idea when you mix and match parts. Flywheel and dampener need to be included.
BTW I think returning to a solid lifter cam is a cool idea. Options and details building a sbc are endless but it makes it fun also. Good luck.
I expected to balance the short block rotating assembly for two reasons; first, I have no idea about the state of its balance, never having run the crank. Second, I replaced the rods, pistons, and rings, which are marginally lighter than the originals.
I need to get back up with my machine shop - I expected to deliver only the crank, rods, pistons, and rings for balancing.
So then, I also need to take the balancer and flywheel, then?
Anything else in the rotating assembly also need to be included? Things like the clutch assembly? Pilot bearing?
I've got more homework to do.
In addition to the complete rotating assembly make sure to take the pressure plate. When you get it back there will probably be a paint mark on the flywheel and P/P showing the correct clocking position to mount the pressure plate on the flywheel. No need to take the disc because it spins free inside the assembly.
Verne
You triggered additional thoughts there.
If you have a scale accurate within a gram you should be able to save a $100 or more by weighting everything your self. But let the shop weigh the rod big and small ends if they need as that's a bit difficult. BTW lighter is better for more than one reason. It's easier to remove metal than to add it to the crankshaft. Also lighter pistons & rods stress the rods much less. I believe tensile and compression stress increases exponentially with RPM/engine speed.
I think I'll start another thread on the techniques of engine balancing.
Even the commercial links I looked at on line seem to disagree.
I agree with you in theory, but any time you start stacking up parts like a bolted pressure plate to flywheel there is always a chance of mismatch. The flywheel will be zero balanced then the P/P bolted and weight added or removed to maintain this balance.
If not checked/balanced as a assembly and there is the slightest difference in the pressure plate then after it's bolted to the flywheel you have just installed a eccentric weight to the back of your motor.
I would think checking balance of all the parts together would be better, but what happens when the clutch, disc and sometimes the flywheel wear out. Most shops would just replace the parts with out disassembling the motor for rebalance.
Easy Rhino. You need to take a pair of connecting rod bearings along for the balancing operation to make the bobweights.
Looks like the crank goes in first before balancing to confirm my journal measurements then.
I don't want to buy bearings until I confirm the sizes.
Received 1,843 Likes
