C2 Headers/Exhaust Recommendation
I’m almost at the point in the restoration where I need to buy exhaust for the car. The car is a ‘65 coupe with a 396 tri-power with 115cc aluminum heads and a 4 speed transmission.
What headers and exhaust do you recommend?
I have used Dougs headers on other cars and also was thinking of using the stock 2 1/2 inch exhaust setup with the magnaflow muffler upgrade.
Thanks!
Thanks!
Thanks!
Thanks!
I think you first need to define what your objective is. Simply put, are you going for appearance/bling, or maximizing performance and efficiency?
Side pipes look great, and will give you great noise right next to your ears- if that’s what you want for your driving conditions. Some folks think that gets old pretty fast. Also, side pipes are generally more restrictive and less efficient than under car systems due to the bends in the pipes needed to connect from the headers to the sides.
Most efficent/least restrictive is typically/long tube headers with under car exhaust like N-11 off road system. Definitely go for 2 1/2” collectors and pipes.
For headers I like McJacks out of the LA area. They build a quality product, metallic/ceramic coated on the ourside, and copper coated inside the tubes!
None of the above makes much difference under about 5000 rpm or so. That’s where the performance difference starts to show up. So if you’re typically below that this is all just for appearance anyway. If so, go with what you want for the appearance - or just stick with the Rams horn factory manifolds and save your money!
I bought the Heddman coated headers for my 64 coupe that I am doing a big block swap in. They seemed to be the best "value" for my project. I bought the Pypes complete exhaust system less mufflers ( 2 1/2" mandrel bent with integrated x-pipe) and some Jones Full Boar stainless mufflers. I bought a 3' piece of polished stainless exhaust tube and will make my own slash cut tips is the plan.
I am not a side exhaust kind of guy and this whole setup was about $1000. Price wasn't the final concern, but with another $1000 earmarked for a radiator (DeWitts wound up closer to $1100 with 1.25" tube core and the dual fan setup) and $900 for brake calipers, it certainly was a consideraton...
C2 of Year Finalist (performance mods) 2019
I would recommend uncoated headers. Buy then, test fit and make sure you like them, that you can access your plugs, that they don't interfere with the steering box, etc. Then, once they are fitted and matched with the head pipe and everything else, then send them out for coating.
Sidepipes
I had sidepipes on my little 1250cc Bugeye Sprite. Couldn't hear after about 10 mins. And the ringing in my ears lasted for an hour after each ride. But they did look and sound cool.
But that was 25 years ago. Now I don't hear as well so I probably wouldn't know the difference anyway.
Best of luck...
Dan
1950 Ford F2 pickup
71 E Type
2006 Mustang GT
2016 A5
{looking for a C2 to fiddle with}
Best of luck...
Dan
1950 Ford F2 pickup
71 E Type
2006 Mustang GT
2016 A5
After reading all the post here is what i have..doing it for performance and sound. Car will be a power steering vintage air ac car, rather go with full length than shorties, exhaust ports are stock location.
The only reason i was going with a stock repro kit with magnaflow muffler is everyone says the corvette central kits fit with no issues.
Ill check out N11 and McJacks
The following 2 users liked this post by 64tux:
beatlescott (09-14-2021),
southsidestingray (01-14-2021)
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
The chrome ones look good on the dark colored cars and the flat black ones look great on the lighter colored cars.
I have the Heddmans too. Jet hotted after the fitting.
Cut the flanges off a set of stock side pipe tubes and welded a collector flange to em. Looks stock. Lined up real well, no tube work. It is a little loud but I like it that way.
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Well then all you need to do is put a few 3/8 hole flat washers under the nut on a factory PS bracket stud so that the nut is in about the same place it would be if there were a factory exhaust manifold under it. That should put the bracket in the proper alignment.
What size headers are you using? Most i see is 2” primaries with 3” collector for a 396.
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
For a 396 I'd step down to a 1-3/4 or a 1-7/8. You don't need 2" unless you're really going to mega RPM.
JIM
JIM
