[C2] Strange Temp Issue
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
Update.......
Checked voltage on the battery at 2500RPM. Got almost 18V. Replaced old Delco Remy 515 with a NAPA part. Rechecked and now maxes out at 14.4 so it looks like problem identified and solved. Will run the knock off VR for now and take a drive and see if the temp gauge issue is corrected which I am pretty sure it will be.
Plan now is to convert the Delco to electronic down the road.
Thanks for all the good tips and have a great weekend!
Update.......
Good news, and avoided many other problems down the road. Check your points for pitting if you still use points.
Took a good 30 mile drive today and temp seems to be rock steady. So problem solved.
Will check points to make sure they are ok. Probably are as I have parked it since the problem showed up and drove less than 20 miles.
Thumbs up to all.
Thumbs up to all.
Received 2,130 Likes
2015 C2 of the Year Finalist
Dan
smacota1 (01-20-2018)
