66 BB TI Ballast Resister Question
Getting conflicting information so i'll bring it up yo you all.. Do you need a Ballast resistor for the T.I. K66 set up in a 66 BB? If so suggestions on where to obtain one? Ecklers has Ballast resistors "except T.I.)
thanks
thanks
wolfman74c
You only need the ballast resister if you are using points, it lowers the voltage from 12 volts to 7-9 volts, and if wired to the r terminal on your start solenoid it applies 12 volts during cranking.
No............
Larry
Larry
Except if the original TI car was born and raised in a small town where the Chevy partsman and mechanic held a TI distributor in their hand and said "What's this?". Pretty soon, you had points and a new hole in the dash.
awesome.. thanks.. i had gathered a lot of T.I. parts when i had my 69 BB and just happened to have the correct numbered and dated parts for my 66 BB so i decided to put them in and back to work. can always take them out if i sell. ( not likely).
thanks
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
The ballast does not lower the operating voltage to 7-9 volts (it's a resistor, not a voltage regulator). The ignition system runs off of 12v battery or 13-14v alternator output. The points and coil deal with 12v at the start of every ignition event. It is only after the points close and the current starts to ramp up that the voltage across the coil gradually lowers from 12v.
The R terminal is there to shunt the ballast resistance to maintain sufficient coil current, not voltage, as the battery frequently drops well below 12v during cold weather cranking. It's rarely needed during warm weather easy cranking conditions.
The Ignition Physics Sticky in C3 Tech explains all this in more detail.
You need a ballast resistor whether you're using points or a TI transistor switch. Otherwise both systems will burn up from excess current and power dissipation.
thanks jcw
thanks jcw
