4th edition 67 judging guide LOL!!
And a one-off in no way implying it was a factory practice...that is a different story than the 'they ran out of SB hoods so used BB hoods' myth.
Here's a shot from an owner that claimed his car definitely came with a big block hood. He even provided this picture, on request, as proof and posted it on that other board. He claims that the hood support reinforcement was definitely originally installed on the left side.
Received 6,943 Likes
2015 C2 of Year Finalist
That aged very well compared to the hinge plate.
Received 1,283 Likes
OK, I can't resist...
A number of us are aware of the backstory associated with the entry in Noland's book.
Without going into details, let me just say that Noland many times stated that he wished he had never put that statement about the damage to the small block hood mold in his book.
I personally heard Noland make that statement at one event.
[QUOTE=Critter1;1596559581]If the hood support and under skirt reinforcement was originally installed on the left side, it could possibly mean the big block hood was factory installed on a small block car.
Unfortunately, no one has ever been able to show or prove this. Filling the unused hood support reinforcement holes on the right side can't be done to appear as original fiberglass.
I agree. In my opinion, it never happened
My '67 has a hood support on both sides. It has a repop BB hood on it (bought it like that) and I have the original SB hood also.
Like many parts, if not all, a fake could be made. the mounting location of the hood support could be switched and the evidence that it was once on the other side could be erased.
[QUOTE=Jeffthunbird;1596564406]
There's a 66 that comes to a local car show that the owner claims is an original big block car. I looked at it and I could easily see where the original holes for the hood support had been filled. It's easy to fill the holes but doing so without removing the original rough grain of fibers in the glass is not possible. The area was sanded smooth after being filled on both sides of the fender skirt. Pretty obvious.
Received 5,010 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Back when I worked in an assembly plant I heard a story about the general foreman's car going down the line in the body plant. All kinds of extra spot welds and other welds were added and when the car was finished the story goes the body was so stiff it rode like a tank.
#33
Received 1,843 Likes
AM radio, clear glass and on and on.
When the car went down through the trim shop and down final, it had tinted glass, upgraded upholstry and seats, 390 Police INterceptor engine and heavy duty transmission. 9 inch nodular axle, Interceptor suspension and tires. Twice the normal under lay under the carpet and double sound deadener in the body itself.
The alterations were caught on the Final Acceptance line. The employee that bought the car war first fired, then re-instated on the condition he pay for every extra that car had on it. He was convicted by testimony from his fellow workers who had put on the unauthorized parts and who were threatened with termination if they didn't talk.
That car (one of a kind) went right on out the convoy gate, to the dealer and then to the customer.
This practice was not all that uncommon. Where this guy made his mistake, he didn't let management in on it. The same ones who could have "approved" the upgrades.
I personally built a very nice customized 1978 LTD model. One of a kind car and it didn't match the build sheet either. One of the special things on it was an LTD steering gear built up with F 150 internals to give the box a quicker ratio and much better feel on the road. Not to mention all the Interceptor suspension pieces and the related wheels/tires.
Do to truth in advertising laws and other Fed regs, you couldn't get away with this today. Back then, very common. I believe prior to the era of Big Brother, the assembly plants back then (all brands) were run in some cases like the wild, wild West.
But, in our plant, we also did a lot of custon work for Engineering on work order. It was a good money maker for us as the employees were always eager to see something besides the SOS come down the line and even the custom stuff didn't interfere with production. We always charged Engineering with money for a production loss but it never occurred except for the one "custom" job on the work order..
Based on conversations with several GM people, seems like they didn't care to run the business that way and most production mods were done on a regular production car at the Tech Center.
#34
Same here at the Ford Plant except the car had a lot of squeaks and rattles as well as being too stiff. Plus, the order sheet said 352, two barrel carb engine with the cheaper auto transmission an small axle.
#36
These "special" cars were always for a Company Public Relations guy........
#38
Anyone who is knocking the manuals should form there own club of any car that was built over 50 years ago and write a manual on how they should look. Then we can see how many mistakes you made. Also you should try and restore anther car to original with out any manual and only use info from others and see what it’s like.
The following 2 users liked this post by Nowhere Man:
Chuck Gongloff (02-13-2018),
Rick Gower (02-13-2018)
#39
The problem is the way the current manuals evolve and the refusal in some cases to accept changes by knowledgeable people.. Critter1 on here is an example... His corrections were ignored, in part or completely. So mistakes continue on or more are introduced. They become a prideful symbol of self-aggrandizement instead of a faithful tome to be relied on for the hobbyist. I'm also sure that if enough traction is gained by someone with influence to have their own little quirk added to the documents that a revision could creep in that has nothing to do with reality... This 67 manual could be a prime example.
Here is some history from the NCRS web site (why the post wasn't expunged by that forum's "Gods" I don't know) by somebody that knows about the 63/64 manual. And this is before the penultimate expert, current 63 team lead, had his way with it..
I wholeheartedly acknowledge they are the best we have and far better than the documentation for other classic car marquees, but they could be so much better.
#40
