[C2] 63 crossmember cushions
I'm about tired of looking at the cracked and crumbling rubber on these sombrero soft parts. Does anybody have JohnZ's magazine article on getting the crossmember off (I have access to a press) ?
I did some searching on here on the step-by-step but the pictures referred to in the threads were all photobucket and access is long gone
I’m talking more about cookbook instructions for the whole job E.g.
1 drain differentiL
2 disconnect driveshaft
3 disconnect half shafts
4 etc.
1 drain differentiL
4 etc.
I would think that the Shop Manual gives the steps involved. It's relatively intuitive to be sure.
Two more things:
If you decide to break loose both sides at the same time, be sure to install long bolts in the sombrero mount holes to act as safety stops which will prevent the entire assembly from abruptly hitting the floor when they break loose. The sombrero-to-frame contact points are metal-to metal, so a lot of PB Blaster will help. Multiple applications are better over course of a a few hours or so.
Be sure to fully torque the 4 spring-to-carrier bolts ONLY after full assembly and the weight of the car is fully on the spring. If you don't do this there is a risk of breaking one or more ears off the pumpkin rear cover when the spring stretches under load.
Two more things:
Frankie the Fink (02-17-2018)
Thanks - a forum member sent me the JohnZ article via email. This is the 'short method' that doesn't require the disassembly of the rear suspension and resetting the caster (as per the shop manual)...
I did my sombrero mounts a few years ago on my 63. I used the John Z article with a few mods. After removing the spring and half shafts and removing the tail pipe extensions and the muffler hanger and tying the mufflers outboard. Disconnect the camber control arms, aka, strut rods at the spindle support. Unbolt the camber control arm bracket from the carrier, store the unit. I removed the bolts that clamp the cross member to the frame and replaced them with a longer bolts. I used a long 2x4 and popped the sombrero's clear from the frame letting them rest on the longer bolts. I fabbed up a plate that bolted to the camber control bolt holes and mated to my small floor jack. Down it came no problems. Hope this helps.
BTW, One of my pet male Red Jungle Fowls that I raised from peep was under the car with me the whole time as a supervisor.
Brgds,
Rene
Brgds,
Rene
Frankie the Fink (02-18-2018)
Sometimes, those sombrero bushings don't "pop" off easily. Ask me how I know.
You're going to need to disassemble the entire rear end... remove the spring, strut rods, exhaust pipes, drive shaft, half shafts, etc. to get that X Member out...
Me? I'd close my eyes when I looked at the rubber. If it ain't broke, don't fix it.
Last time I did it was when I reinstalled my original 4.11 gears, replacing the 3.55's I had previously installed back in Maryland.
AND, I didn't change my sombreros. These are pics of when I took the 4.11's out, and put the 3.55's in back in Maryland.
I got to do it again after I moved to Florida.
This is me not 'closing my eyes' - so you think this is alright ? I'm not so sure...if you read JohnZ's article he had a significant failure on one of these..
I haven't ordered any parts for the job yet....so I'll let it "cook" a while...
Sitting on the pier with enough Corona, cigars and Reggae music chanting, "....every little thing gwanna be awright" and my enthusiasm is quelled
You have the right idea right now. Don a “Sombrero” sit on the pier with a good cigar and enjoy life.
OK...but those cushions look like two bloodshot eyes every time I'm under the car...grrrr...
Using your finger.... SMEAR the RTV into the cracks. Take your time and make it smooth....
Then, forget about it for another 20 years.
Blasphemy!
There are several purists that are now in the fetal position under their keyboards
I'm off to Ace Hadware
Maybe another way to cover the bloodshot eyes is with a few nice cans of spray undercoating.
Silicone is too shinny (shiny?) to pass the NCRS smell test. I suggest adding carbon black too (to?) "dull it down". Think of it sorta like dulling down door jams (jambs?).
Roofing tar might be easier to apply, using a putty knife to work it into the nooks and crannies..
Chuck may know better than me but I don't like the way they look, I would pull that car into pit road and get um fixed.
Guess you can figure out what I'm watching. :-)
