[C2] Firewall hole?
Our '65 has two holes in that vicinity the large hole is for the firewall insulation rubber fastener and the smaller one is for battery cable clip. This is a BB so it has a left side battery.
There is a hole there for the firewall plug as shown in no. 4 post. It's hard to tell from your picture if that is the hole you are looking at.
Is there a similar hole directly above it? Those holes as mentioned are for the rubber plugs that hold the insulation against the firewall (on the interior) and protrude thru these holes. Here's what the plugs look like. Bill
Yup, bubba has been working in there and chewed it out large enough for a mouse to live in your interior during cold weather.
You're gonna need a little fiberglass repair there to close that up and re-drill to the correct size for the rubber plug.
