Ignition questions on 57 283 in 57 Vette
Has anyone tried to fit an MSD distributor inside the factory shielding on a 57 carbureted Vette (2x4)? I would like to fit an MSD distributor with vacuum advance; I can hide the 6AL digital box elsewhere in the car, but I don't want to give up the factory shielding. I know MSD make small distributors, but I don't think they have vacuum advance capability. Anyone who has tried this, or can enlighten me, thanks in advance for your help. No pun intended.
St. Jude Donor '05, '09, '15
I use an MSD 8572 tach drive dist on my 65. It uses a small diameter cap and a standard vacuum can. You can us a tall cap or standard height. I do not use ignition shielding but I would expect it to fit.
Tom
Tom
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
Received 1,973 Likes
Years ago I recall someone saying they were able to install a Delco single point dist. with a VAC on a 2 x 4 283 and get the timing right, but it required rotating the gear 180 degrees so the dimple faced opposite the direction as the rotor tip.
Personally, I'd just use points as they are simple, reliable, rarely fail without lots of warning signs, and don't need frequent adjustment given the typical low mileage accumulation of most vintage Corvette; but you have the option of replacing the points with an electronic switch that can fail suddenly without warning. So, if you do, carry a set of points and required tool in the car to install the points when the electronic switch fails.
Duke
Duke
