New or Rebuild ?
New or Rebuild ?
66' Holley acting up. Have adjusted the floats and idle screws but still having problems. Trying to decide whether to buy a new carb or have mine rebuilt. If I decide to replace it with a new one, any suggestions on what to get? Car is a 327/300hp. Thanks.
Skydude
Skydude
Received 2,127 Likes
I'm not running a Holley, but I will suggest you do a search here on the CF. Holley carbs have been well discussed about rebuild, sources for the work and replacement Holleys. Dennis
Received 3,443 Likes
I'd rebuild it. Have you priced a new Holley lately? I've paid less for entire engines.
Wrestling with the same issue on my 67 L79. I was thinking about getting a new Holley 600 ($300) to run until i figure it out. Brand new 3810 is over $700.
Is there an easy way to get fittings to adapt the steel fuel line on a 67 to a new Holley ?
Received 6,943 Likes
2015 C2 of Year Finalist
Get it rebuilt and restored by the right shop and your be good to go. I have had good luck with Custom rebuilt carbs in NJ. There are others who do just as well
Received 1,534 Likes
Sometime the carb is blamed for the electrical problems. Make sure you are correcting the right problem.
If you have the original carb, it was built for the engine. A new generic Holley may not come with the correct choke and fuel line configurations requiring modifications to your systems. Also, the new carb will have to be tuned to your engine, possible jet and power valve changes, etc.
I would spend the money to have it rebuilt, if you can't rebuild it yourself. It is not a difficult task if you buy the Holley service manual and pay attention to detail.
If you look, market value for a "junk" but proper date coded Holley goes for a ton of money and they're not functional/need to be rebuilt, plus there's the turn time on a rebuild. If I care about the money, anytime I wish I can sell Holley I removed and have less net out-of-pocket than a rebuild would have been assuming that the whistle was moderate warping to the base that can be fixed.
It was 4 years ago and around $600 new for the carb. There's a California outfit that "sells" junk Holleys for these cars at $500 for those that are hunting date code correct carbs for top flight, etc.
If originality is important, then rebuild an original, as the OP should do.
Just wanted to throw this out there for those who are in my situation: non-original to the car carb, wanted something that was simple bolt on with no changes, and not wanting to send a carb away and wait to get it back.
