[C2] Holley Parts
Holley Parts
Greetings,
I recently found a pair of small inlet float bowls for my 3124 list, 1966 dated Holley carb for the 65BB coupe. Just the bowls, no floats, accel pump, etc.
Do any of you super smart Holley guys happen to know correct part numbers for this stuff?
Perhaps a source? I'd prefer to have older more period correct parts than new flossy shiny stuff.
Thanks Y'all!
Carter
Thanks Y'all!
Carter
Carter, you might want to check out companies like Vintage Muscle Car Parts. They offer a wide variety of services related to vintage carburetors. They are no doubt a good source for correct parts as well.
There's also some good info in these post related to the 3124...
https://www.corvetteforum.com/forums...placement.html
https://www.corvetteforum.com/forums...-question.html
https://www.corvetteforum.com/forums...ode-533-a.html
Good luck... GUSTO
Good luck... GUSTO
71scgc (03-02-2018)
Try this:
https://www.holley.com/products/fuel...or_components/
You can also try this (at your own risk):
http://www.chicagocarburetor.com/carburetor-parts.php
71scgc (03-02-2018)
The link below is page 1 out of the Holley Carburetor Numerical Listing index from the Holley Technical Library. List numbers are in the left most column and reading across the sheet, you'll see part numbers for most major components.
71scgc (03-02-2018)
