[C2] How do you rebuild wiper transmissions?
2019 Corvette of the Year Winner
St. Jude Donor '15
I found mine and while they move, I would say they are a bit on the tighter side. Is there someone that does rebuild them? If not, anywhere I can find some instructions and parts?
Uh for a 63 ??
Let them soak in some penetrating oil.
Hey Herb.
Like you the wiper transmissions on my 63 were very stiff in operation by hand. I took a small drill bit and drilled through the aluminum about half way between bottom and top. The drill bit will let you know when you are through the aluminum and contact the steel shaft in the center. Inject some light oil in and work the units and they should free up. Then you can take a round toothpick, plug the hole and snap it off. All done and working freely.
Bluestripe67 (03-09-2018)
Received 2,126 Likes
Hey Herb.
I’d prob put dum-dum over the hole but yeah that’s basically it. These aren’t the complicated gizmos like on a C1 herb. They make plastic transmission covers too to keep moisture out. Not original for 63 but they fit just fine.
St. Jude Donor '15
Hey Herb.
St. Jude Donor '15
Since there will not be much original when I am done that is ok. I like the idea of the covers, they can make them look like new on the outside then! Thanks.
St. Jude Donor '15
uh, I bought a totally disassembled car.....so this isn’t a big deal. The challenge is when I am looking for parts and not sure what I need. That gets to be the challenge! I found all the inside and outside rear window trim so that is a relief. But since I sold my other 63swc I have to rely on the assembly manual and vendor drawings and of course all of you!
Attached is an article I wrote about lubricating the wiper transmissions.
If you don't plan to use them much, you can probably work in some oil from the outside without drilling the hole. However, if you want them to be ready for serious duty, it's probably best to fully "recharge" the dried out Oilite bushings.
Luke 1967 (03-30-2018)
St. Jude Donor '15
firstgear (03-11-2018)
firstgear (04-16-2018)
Just a quick thanks to Joe for your article which I used to guide me through wiper arm transmission cleaning and re-lubricating. I had similar need as FirstGear. One of the arms was very stiff. Drilling the hole (and set screw), and recharge of dried out bushings was the perfect solution for me.
Wow, those look beautiful! I'm glad my article was helpful.
Hopefully those wiper transmissions won't need attention for another 50 years.
