Yet another home built C2 body dolly.
Received 1,900 Likes
Just about ready to remove the '63 body from the frame.
Put together this body dolly using stuff I had around the back of the house.
Probably overbuilt a bit, but it should work good for moving the body around.
I only have one of the braces welded in. Once I have the body lowering near the dolly, I can make minor adjustments, and then weld the others in place.
Pat
Pat
ptjsk (03-10-2018)
ptjsk (03-10-2018)
ptjsk (03-10-2018)
Nice. I like how you bent the tubing to clear the damper and drive line.
Don’t forget your shim packs.
