[C2] Speaker Grill Restore
I looking to refresh the speaker grill on my 67. Not sure how to go about removing the pitting and preparing for paint. My first thought is to sandblast with glass bead. I would appreciate some feedback from any of you that have tackled this before I do any irreversible damage!
Also, I am planning on using Dupli Color Trim and bumper paint, apparently similar to SEM trim black and Krylon 1613 semi black (both of which are next to impossible for me to find in Canada). Any comments on this paint?
Luke
Luke
Received 6,943 Likes
2015 C2 of Year Finalist
I would sand blast it. then paint. John Deere blitz black is close as well
Update on speaker grill restore
Ok, went ahead with the light blasting keeping pressure at 100 psi and scotch-brite. Cleaned pretty good but you can see the pitting has worked its way into the metal in some spots. At this point, I'm thinking sandable primer before painting. Will update after paint.
Thanks for your responses.
get some glazing putty tape off the screen part and apply, then sand repeat if you need to
Sandable primer will fill the bill IMO. That grill gets no wear and doesn't contact anything so building the low spots up with primer until the pits are gone and then shooting color should work just fine..
[QUOTE=Nowhere Man;1596757501]get some glazing putty tape off the screen part and apply, then sand repeat if you need to
Yes, good idea,
Thanks!
Yes, good idea,
Thanks!
if he tapes over the speaker grille yes the more paint you shoot on it the smaller the holes will get
Luke
Luke
Be careful how much paint build up you put on the part. IMO, the very small pits I see will dissapear when you spray paint it.
This job finished
Luke
Luke
As some of you suspected, pits where not too bad, I blasted with glass bead, masked the center area with the small holes, then 3 coats of primer with sanding in between was needed to fill the pits but did not need filler, removed the masking in center, and paint.
SEM gave beautiful result, but beware you need good ventilation. My garage is attached to the house and even with garage door open, the odor in the house was quite strong. I have another batch of parts ready to paint, but its gonna be outside when the weather allows!
Thanks for your input
Nice!!!!
Looking good.
