Brother's 67 Convertible
#301
You did really well, especially pulling the motor - trans from the side. Every Corvette driveline I removed over the years was from the front of the car. A lot easier. Park the car in backwards when you put it all back together.
elwood13 (07-08-2018)
#302
Thanks Jim. I debated about front or side after reading the different methods. I watched a YouTube video of a guy pulling from the side on a C3 and just did that way since I could fit everything in the garage as it was getting dark. Hopefully I will be reinstalling it on just a bare frame.
#303
Anybody have one of these come with their car? I can’t remember exactly where it fell out but I think it was from that exhaust crossmember bracket part. It was a solid cristy black blob. My friend was looking at it and thought it was as bone so he cleaned it up. He thinks it may be a moose whistling tooth but he have no clue.
#305
Received 1,901 Likes
Looks like Elk whistlers, but much larger. Fortunately, I have many. I'm not aware of Moose having "whistlers" though.
Either way....makes you wonder how it got under there. Did your car run over something several years ago?
Keep it with the car, and have a key chain made out of it.
Pat
Pat
#306
I think I meant elk but said moose. I never see any around here so I guess they are both the same to me. lol. My wife wondered if that is what cause the damage to the front. I told her I think there would have been more damage if a moose/elk was hit. Here are couple pics of the clutch and flywheel. Going to do a separate thread on the 327 as I am not sure the best way to sell it.
elwood13 (07-10-2018)
#308
#309
Received 1,857 Likes
#310
[QUOTE=elwood13;1597561671]
Could it be a oyster shell, remember that car came from the land of pleasant living... :-)
[/QUOTECould it be a oyster shell, remember that car came from the land of pleasant living... :-)
#311
Thanks John, Too much water over the dam. My old brain is forgetting items. All I remember, is changing many of both items on manual trans Chevrolet cars and Corvette that customers owned over the years. EACH unit is probably hard to find today
#312
You could be right tbarb. I scrubbed it with degreaser for 10 minutes.
#314
Thanks guys. I did find the borg and beck on the front. Is this clutch still good and would it be worth anything?
#315
The flywheel may be worth having a machine shop resurface, but the pressure plate is just too inexpensive to take a chance on. A machine shop would be able to tell you if the flywheel will clean up, but I would definitely replace the PP.
Good luck... GUSTO
elwood13 (07-12-2018)
#316
Personally, looking at the thickness (area around the rivets) of the disc, there is no way I would put that back in. The surface of the pressure plate and flywheel don't look that good either. It's hard to tell if they have heat checking on them from the picture.
Good luck... GUSTO
Good luck... GUSTO
#317
Thanks guys. Looks like more stuff for the metal recycler.
#318
Experience taught me not to throw out anything while doing a resto. If you have any out of the way space a small shed or even an area you can cover things on a skid with a tarp dont ditch anything until your revival is done.
#319
Thanks Phil. I’m keeping a box/pile for everything and then see what I can possibly sell/give away and what will go to scrap. I still have the rusted bent gas tank and rusted exhaust. On a side note I was curious how well the klean strip paint remover worked. I spent about 15-20 minutes on it having never done this before. Brushed the stripper on and within a couple minutes the paint bubbled up. Used the plastic scraper and scooped it off. Then brushed some more stripper on the grey and red primer and went work on it with a red pad. Rinsed it off with water and still had some red primer. Filled up a clean red pad with water and just rubbed on it for a little bit and the rest of the primer came off. I did have to rinse the red pad several times. After that I just hit it with some water and a rag. Hope I'm doing this correctly.
