Brother's 67 Convertible
Old 02-08-2019, 11:50 PM
  #501
emdoller
CF Senior Member
Looking good. Glad to hear your son is ok.
Ed
emdoller is offline
The Following User Says Thank You to emdoller For This Useful Post:
elwood13 (02-08-2019)
Old 02-08-2019, 11:52 PM
  #502
elwood13
CF Senior Member
Support Corvetteforum!
elwood13's Avatar
Forgot the kid rotor pics. The pic of the car is after the impact with the curb and this is where he ended up pulling into the business. I know its a tangent to build thread but oh well.
elwood13 is offline
Old 02-09-2019, 01:44 AM
  #503
Factoid
CF Senior Member
Factoid's Avatar
I cringe when I see that, but pass out when I hear the estimate!
It’s part of the build thread as it impacts the financing. Have you figured out what you are going to do?
Factoid is offline
Old 02-09-2019, 02:37 AM
  #504
ptjsk
CF Senior Member
ptjsk's Avatar
Hey Chris,
Unfortunate for your Son, but glad he's doing ok.
Your car is looking great!
I haven't worked on the '63 all week. We lost power when this big storm hit, and tomorrow starts the 5th day of no power.
I crawled up in the attic yesterday, and was able to get the heater going.
Pat
ptjsk is offline
The Following User Says Thank You to ptjsk For This Useful Post:
elwood13 (02-09-2019)
Old 02-09-2019, 03:56 AM
  #505
Micksnip
Junior Member
Originally Posted by elwood13 View Post
Thanks Dennis and vettevt. I think I have everything major listed out that this noob can think of to get her safely driving. I know there will be some small things, lights, wiper blades etc. I may have some parts that are fine and I am just not giving them credit because of age or everything may be bad. Please let me know what I missed, cause I'm sure I did. Also, the books I listed on page 4, there is a 68 manual that I don't think I need. If someone needs it let me know and I will send it to you. Warning,
it smells like old books. If I understand the forum rules correctly, I can ask about part brands but be careful about vendors, correct?
Change all fluids
Radiator – Cleaned / New hoses and T-stat
Carb – Rebuild or replace
New plugs / wires
New beltsMotor – complete go through or start and see what happens (I lean to complete tear down) New correct oil pan
Clutch – Replace? Do they go bad sitting?
Brakes – New Master cylinder, lines, calipers, pads
Tires – New
Fuel tank – New (old one is patched and rusty inside)
Wiring harness – test first before replace or just replace
Front End:
Replace upper/lower control arm bushings
Replace sway bar bushings
Replace ball joints
Replace tie rod ends
Idler arm
Pitman arm
Relay rod – keep or replace
Wheel bearings – New
Shocks - New
Rag Joint ?
Steering box – clean and redo
Rear End:
New Shocks
Replace Strut rod bushings
Replace Control arm bushings
Replace Rear stabilizer bushings
Axle shaft U-Joints – New
Drive shaft U-Joints – New
Rear wheel bearings – New
Rear end – New seals or complete go through
Transmission – New seals or complete go through
Rear spring liners – replace or leave alone
BodyNew seat belts – only have half a seat. Wife wants shoulder beltsWife wants headrest seats – I have to research if that can be added to existing or buy complete Side window weather stripping
In addition to the manuals on page 4, from what I have searched here, I still need an AIM manual, Noland Adams Resto book and maybe an NCRS manual. Anything else I missed?
Thanks in advance
elwood-congrats, man, on your vette. Whatever you do, keep “spouses interest” alive by asking her for a favor- and have her in on the procedures. Your main goal is to use this as a family bonding tool, and safe drivability should be your target, and everyone adds their 2cents. BUT, don’t push it, and mistake their cultured interest as license to dismantle everything, unless they want to!?! I have seen these projects draw together or pull apart families. It costs money, time, and you. And everyone usually misses the us that used to exist. So, get that rod driving safely, without taking juniors college $ to buy those can’t do without mag wheels! In my other interest as a music player/equipment freak, and the term used to rate speakers was called WAF, for wife appreciation factor. Big speakers =(sort of) bigger/better sound is equal to big vette undertakings do cost somebody something that came from doing something and diverting it to a hobby fund. Be careful, even though you are the owner, it’s best as a family affair! Ask me how I know!
micksnip
Originally Posted by jsans View Post
OK, dumb question time.....
For these original 461 head specs, what does it mean to have no accessory holes? I've heard of some people drilling them, why would they and what would they be used for? Looking to rebuild my original block. Thanks.
62cc
2.02/1.94
1.60/1.50
Double hump heads, no accessory holes 160 cc runners
302/327/350
Micksnip is offline
The Following User Says Thank You to Micksnip For This Useful Post:
Old 02-09-2019, 08:07 AM
  #506
hcallaway
CF Senior Member
Default Looks Great
If I can ever get close to those gaps I would be so happy!
hcallaway is offline
The Following User Says Thank You to hcallaway For This Useful Post:
Old 02-09-2019, 11:16 AM
  #507
elwood13
CF Senior Member
elwood13's Avatar
That’s not good Pat. Guess I need to get the older son to hurry up and finish lineman school so he can get your power back.
I get what your saying Mick. This whole thing changed because of my wife. I’m doing way more than I originally thought. As far as funds, I’m dipping into my hobby fund to fix the boy’s driving mistake. His college fund is safe and our just in case of emergency fund is safe (which so many people don’t seem to have now days). I’ld rather slow progress on the hobby than try and repay the other funds.
Holt, I think you will get all your lines just as good.
elwood13 is offline
The Following User Says Thank You to elwood13 For This Useful Post:
ptjsk (02-10-2019)
Old 02-10-2019, 02:37 PM
  #508
Vette5311
CF Senior Member
Vette5311's Avatar
Project looking good.
I pulled the e brake on yesterday in the garage while working on the car so it wouldn't roll in neutral and it stuck on! I guess the cables are corroded and wouldn't release. Glad it happened at home. I got under and backed the balance bar adjusting nut off and it released the pressure so I guess that means the problem is in the front rather than the rear cables but not sure, have to investigate further, always something.
Any way glad your making such great progress, keep it up.
Vette5311 is offline
The Following User Says Thank You to Vette5311 For This Useful Post:
elwood13 (02-10-2019)
Old 02-10-2019, 04:22 PM
  #509
elwood13
CF Senior Member
elwood13's Avatar
I’m just glad you didn’t do like my brother and tie ropes to the bumpers and give her a pull.
elwood13 is offline
Old 02-11-2019, 02:59 PM
  #510
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Great thread Chris! Not sure how I missed it up until this point, but just spent the last hour or so reading the whole thing. I'm glad your boy is ok....hopefully the banged up Honda won't slow you down too much.
FLYNAVY30 is offline
The Following User Says Thank You to FLYNAVY30 For This Useful Post:
elwood13 (02-12-2019)
Old 02-11-2019, 06:59 PM
  #511
GTOguy
CF Senior Member
GTOguy's Avatar
Glad your son is ok, Chris. Those are the strongest wheel studs I've ever seen. I have never, ever, seen a rotor break like that. Usually the wheel or steering arm or control arms go. Crazy. Good luck with the project, and again, thank you so much for gifting me those spark plugs...my GTO thanks you!
GTOguy is offline
The Following User Says Thank You to GTOguy For This Useful Post:
Quick Reply: Brother's 67 Convertible
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
