Tire recommendations 1965
Former Vendor
so many tires
looking for radial blackwall, 225/70/15, street driven
Putting on 15x6 wheels
Street and highway driving--am sure 100mph will happen on occasion, but only short bursts (as when running through the gears then shutting back down).
thanks
g
thanks
g
Received 1,973 Likes
The minimum recommended wheel width for 225/70R15 is 6", and your OE wheels are 5.5". Search 215/70R15. You might be able to find a couple with a H speed rating. That means they should have a spiral wound nylon cap belt, which is a big safety feature. If there is an internal structural failure this additional belt will usually keep the tire from disintegrating.
T-rated and below lack this feature.
The tire landscape is constantly changing, so what was around last year may not be around now, but there may be new entries. Do a general Web search for the appropriate size(s) and also search the big online retailer sites.
Yeah, it takes some time, but how often do you have to buy tires for a vintage Corvette.
Duke
Duke
Received 1,390 Likes
2021 C2 of the Year Finalist - Unmodified
2015 C3 of the Year Finalist
I use 205X75X15s on my '64s, fit well on the wheels, and in the wheel wells, no issues, and ride great. You have several choices of brands, like Goodyear and Hankook.
Former Vendor
Amended post #1 to reflect driving needs/habits.
Having a difficult time finding H rated tires (has the speed rating system changed?)
Any thoughts on Toyo tires?
Thanks again,
G
210-748-4693 for texting
Thanks again,
G
Uniroyal Tiger Paw AWP-II tires will fit your needs, reasonably priced, widely available, nice looking tread pattern and wear well. An occasional 100mph sprint is no problem.... Sustained triple-digit, high speeds are a different ballgame...
And Uniroyal is an OEM supplier - will even get you some judging points!
Firestone FR710's 215/70R15's
I have Firestone FR710 – P215/70R15 on my 66. 5YR, 65,000 warranty. About 2000 miles on them and very satisfied. Paid just over $400 mounted and balanced.
If you want a black wall radial that has high speed characteristics and great handling get Avon CR6ZZ. I have a set of 205/70R15 on my SWC and am getting a set of 215/70R15 for my 67. Pricey but well worth it. Goggle them
Tim
Tim
Cruise-In III Veteran
You can't go wrong with Michelin Defenders. These tires are radial redlines in a 215/65R/15 from Diamondback.
Jim
In God We Trust!
Jim
In God We Trust!
C2 of the Year Finalist - Unmodified 2020
C2 of Year Finalist (stock) 2019
just Ordered these H rated uniroyals on amazon for my 65. $75 a piece delivered
Uniroyal Tiger Paw Touring HR Radial Tire - 215/60R15 94H
Continue searching 215/70R-15 and maybe you will find one with a H speed rating. Check tireseasy.com. They may have a H-rated 215/70, but it will probably be a brand you have never heard of. If not, search 205/75R-15. AFAIK nothing in this size has ever had a nylon cap belt or speed rating greater than T, but there are a lot of offerings.
Toyo is a top quality tire manufacturer. I have a set of their Proxes RA-1 DOT legal racing tires on my Cosworth Vega.
The Avon V-rated CR6ZZ that SWC Tim mentioned is also a DOT legal racing tire. If you are into attacking twisty canyon roads or contemplate open track events, they are the only way to go. With poly front anti-rol bar link bushings, "sport" alignment settings, and rebound adjustable shocks like Spax or QA-1 they will pull about 1g lateral versus about 0.75 for just about any other tire.
As is the case with all DOT legal racing tires the wear rating is low (80), but in normal road driving with occasional "blasts" they should last about 10K miles.
Search for the Avon Web site and Roger Kraus racing in the SF Bay Area.
Duke
SWC Tim (04-11-2018)
According to the CR6ZZ spec sheet, both have nearly the same inflated OD. As you would expect the max. section width on the same width wheel is about one-half inch wider, but the BIG difference is tread width, with he 215/70 being nearly an inch wider.
Tread width is a tricky measurement depending on the shoulder contour, but my concern is that the 215/70s may interfere with the fender well lips with OE '67 6" wheels.
Duke
Duke,
Will do. Just not sure when I will get the next set of Avons maybe this summer or possibly next summer. Bought the 67 in January and had it shipped to Ohio, we are in the FL Keys for the winter. So not real sure about the tires presently on it. Do plan to carefully check spacing with the fender lips before ordering. I know the CR6ZZ made a real difference on the SWC. Have not been able to break the rear loose in a corner.
6T5RUSH (04-11-2018)
