Engine cleaning
Engine cleaning
Would appreciate any tips on best ways to clean C2 engines - what others have found are the best cleaning agents, what to protect from water, etc. I'm mainly concerned with oil and dirt buildup on my 327/300, not major restoration.
Do I mask off distributor, carburetor and alternator, spray it down with simple green and hose it off, or are there better ways?
Thanks,
Bob
Thanks,
Bob
Received 2,126 Likes
It all may depend on how dirty it is. Anything caked on will need scrubbing or scraping. Beyond that, warm the engine up, cover/wrap the alternator, carb and regulator with foil. Spray Simple Green or equivalent on, let it sit a while, then spray with low to moderate pressure. This is exactly what I have done for several years. Dennis
Been doing the same as Dennis, aka Bluestripe67.
But yesterday at the BMW dealership I notice that they clean the engines with Acetone aerosol spray cans. Asked the mechanic and he said they also use brake cleaner, but the acetone has less smell. Should tell you I have not tried this yet myself.
Acetone, brake cleaner....really! I'm far removed from being a chemist, but those things don't seem compatible with sensitive components under the hood of a car. Dennis
Received 6,942 Likes
2015 C2 of Year Finalist
I've always used a similar process that Bluestripe67 uses with a warm engine but I only cover the carb (with the air cleaner removed) and the distributor with plastic grocery bags. I then spray the engine and engine compartment with the degreaser named Gunk. I let it sit and work for 15-20 minutes before hosing it down with hot water.
C2 of Year Finalist (appearance mods) 2019
When I was a kid I worked at a dealership making used cars ready for sale and we used kerosine with a paint brush, then rinsed with water and sprayed the engine and bay with clear lacquer. I'll bet the dealers still do that today.
It looked almost brand new when we were done, but I often wondered how long the clear took to flake off and look terrible. The kerosine was safer than gas or anything that was very flammable, but the clear was something I would never do to any of my cars.
Gunk, hot soapy water, Presto!
I think if I looked more closely at the BMW mechanic I bet he was just spraying off heavy grease and dirt. But he did use 2 cans of the aerosol.
2021 C1 of the Year Finalist - Modified
I'm in the kerosene camp, I even use it on my Harley's. Small container with a soft parts cleaner brush or a stiffer brush for really bad areas. Rinse with water.
2018 C1 of Year Finalist
No not really when it is very light use. Mostly, I used it on the bolts and such to remove any deposits. Yeah, I am not doing it on the painted body. Just cleaning the exhaust and unfinished surfaces. I have used it on the bare glass underneath. Like i said light use. I did use it with a scotchbrite pad on the exhaust pipes to remove oil from a valve cover leak.
