Sleeping Beauty - bringing my '64 back to life
#142
Received 5,008 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
#143
Some good progress over the weekend, fun to take a step or two forward. I'll make two separate posts as the areas are quite different.
First, my radiator core support was in good shape - EXCEPT for the bottom couple inches, which was mostly just gone from rust. Seemed a shame to shell out $300 for a new one, but fortunately a search on here turned up an old thread saying Paragon sells a replacement piece. It's their part # 1716, it's $100, and it's just what the doctor ordered. That arrived a couple weeks ago.
Saturday a buddy came over and he's an old hot-rod builder who has much better fabrication and welding skills than I do. And he had a bunch of parts which needed sandblasting. SO while I blasted, he cut and welded and put the new piece in. For those contemplating this, he said the worst part of the job was getting the old part off, there were several spot welds on each side which were a PITA.
Anyway, we both finished about the same time so it was a good deal for both of us. yesterday and today I cleaned it off shot an etching primer, and the finish coat, and here you have it!
Before:
After:
Before:
After:
#144
Jim, I'm taking a mid-road approach to that. With a frame replacement, the car will never be "numbers matching". But as you say, if I can reasonably and sensibly save something original, I'd rather do that than wholesale replacement. But sometimes you don't have a choice.
#146
Received 5,524 Likes
No, it’s over rated other than the favorable politics and lack of ridiculous taxes. I love NY, particularly during the summer.
#148
Geez, typed the post out and then clicked something wrong, and it vanished! Second attempt:
Spent 3 days out to the shop, but for the first two I called a "time out" to clean and organize. Some times things just get too out of control and you need to trade the wrench and hammer for a broom and shop-vac. I'm not "Mr. neat" but we all have a limit.
I then removed the glove box, ultimately going to remove heater core, wiper motor, and who knows where project creep will take me. So the seats are out, no soft top in there, rear deck lid was up, and I'm still thrashing and flopping trying to move around under there. I thought back to about 1968, and thought "How the hell did I ever screw in one of these things?
Next was removal of the outer seat belts - I took the inners out long ago. I found out my car was at one point worked on by the most famous mechanic ever - Bubba! As near as I can tell, the brackets are totally gone, and the bolts holding the belts in were secured by a large glob of J B Weld! I ground it away and finally got them out, but it looks like I will need to learn some fiberglass skills before everything gets put back together.
Also took the side cover off the M-20, cleaned up the mufflers, and a few other odds and ends. Not really a kick-azz few days, but progress for sure. And - had the Amish contractor stop by to get me an estimate on doubling the 24x24 into a 24x48. Not sure the budget will allow it, but we'll see what number he comes up with.
#150
Benton, all I can say about the car is I'm having a ball and have no regrets on it. It's just what I wanted and it's the challenges of the process that make it rewarding. And it's many more times as much fun because of the others on here going through the same thing with theirs. Insanity loves company!
#152
Don, this thread by DUB over in Paint/Body should help you with the fiberglass repairs.
https://www.corvetteforum.com/forums...-drag-car.html
The following 3 users liked this post by Hermn59:
#153
No major milestones but progress continues. Spent 4 days out there and between work on the place itself, getting the mower ready for use, and blasting/painting a few parts for my truck restoration, I probably only spent about a day and a half on the Vette itself. But the better half now has the picture hung in the bathroom, and molding around her kitchen cabinets, and had a nice warm fire the whole time we were there, so things are good! Seems we work harder at our "getaway place" than we do at home!
Got the heater box, heater core, and wiper motor all removed. Did some cleaning and prep work on the firewall and shot half of it just to see how it will come out. Also several small odds and ends on the car. The encouraging thought came to me that aside from doing the motor work, I'm winding down on things to remove and take apart. Not totally, but getting there.
#155
#157
At some point when the ground gets less mushy, I'll have to drive the C-4 out there and roll the body dolly out the door for some pics of the two of them together.
#158
Received 2,126 Likes
#159
Yeah, but the ground is a bit bumpy and more than once I have reached down for some liquid and found it bounced out.
I really need something wider than a 46" deck. But I look at the "need" list for the Vette, and then look at the budget, and decide I can coax another year out of the old rider.
#160
Car is looking good. On the grass, you could step up to a 20” batwing and save a lot of time. Money, not so much.
