Knock off question
Knock off question
i found a set of Knock offs for my 66 I bought a while back
coming from Arizona
i have looked and seen a lot of opinions around the web
question is
does anyone here with knock offs use loctite, on the threads, or anti seize, or just clean dry threads?
a few pics of the wheels, and the car they are for
already bought a mother thumper & suction cup for center cap
thanks for any input
Brian
coming from Arizona
question is
Brian
Received 1,919 Likes
Nice car.
I use anti seize, but don't put on too much - it can get on everything.
There are dozens of threads on this forum about proper (and improper) use of knock-offs.
blue max (12-23-2018)
The single most important instruction about installing the wheels:
They will go over the studs on the adapter TWO ways, only one is correct. The large holes in the wheels go over the lug nuts on the adapter, the small holes in the wheel go over the threadless studs on the adapter. It MUST be this way or the lug nuts will chew up the smaller hole, the wheel will work loose and can be catastrophic. When installed correctly the wheel goes all the way up flush and it will take several rounds of the spinner to tighten. The outside of the adapter should be almost flush with the spinner edge. I'll attach a picture of this flushness I'm speaking of and also what the inside of a wheel that has been installed wrong looks like chewed up.
I'm also a new owner of used KO's. Previous car had the direct bolt ons. One thing I noticed on the spare ( haven't taken a wheel off yet) is that the cone is essentially clamped in place not allowing you to see the indexing when installing the wheel. Assume this is going to be the case for the wheels on the car. Some vendors sells longer lug nuts for the adapter which I think will prevent mis indexing.
Received 1,843 Likes
Anybody that would apply loc-tite to KO wheel threads should immediately sell the wheels and buy something else.
Dry threads are not good. Clean/lubed is good.
I don't think you need to wildly pound away on those spinners with an eight pound hammer to properly tighten the wheel. The factory supplied a two pound hammer. An expert can tell you how much more force you can apply with eight vs. two pound hammer.
I just noticed you bought used. Here's an instruction sheet in case you didn't get one.
ReplicaWheels.pdf
ReplicaWheels.pdf
oh, and my hammer is six pounds, not eight
Attachment 48276282
Attachment 48276282
yep, used for two weeks, and then he sold the car
thanks for link😀
I tighten snug with a five pound dead blow (to save wear and tear on the lead) and then give the spinner 3-4 good thumps with the MT. My MT hammer is about ten years old and still in great shape but I'm not one that pulls in the driveway, doors fly open, hood goes up, etc., etc.
I'd never recommend anyone use a dead blow to tighten their wheels. You can easily get much more torque on the spinner with the lead hammer.
silver837 (04-21-2018)
Just curious, why would you take the wheels off to do a brake bleed?
Wjkiefiuk@comcast.ne (04-24-2018)
I guess I could access the bleeder screws on the front without but the rear has both and inner and outer bleed screws. Just looked and I didn't jack the car up but I don't think they are accessible without taking the wheel off. Am I wrong?
Randy
Randy
Received 1,857 Likes
You can't get to the rear outboard bleeders with the wheel in place.
Sorry, I didn't remember the location of the outer bleeder.
