[C1] shock mount repro metal is garbage
2018 C1 of Year Finalist
The front shock mount has so many cracks. I have had to weld it three times now. The darn thing keeps cracking at the bolt where it connects to the lower a arm and the bowl. Its installed right just the metal is cracking.
frustrating!
frustrating!
If you're talking about those lower C1 front shock mounting components, the originals didn't hold up either. I replaced 'em a couple of times myself.
i assume you're mounting them correctly; positioning the tabs as they should be ?!
Received 3,766 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
YEP, but I HOPE you are aware they are EXACTLY the same part on 49-54 pass cars-------------------AND WILL BE A HECK OF A LOT CHEAPER FROM AN EARLY CHEVY SOURCE!!!!!!!!!!!!
Go over to Chevy Talk forum and ask if anyone has some good ones!
Of all the frontend parts that I have, I do not think I have any spare shock mounts-----------------but if I do have any, you can HAVE ONE.
59BlueSilver (04-27-2018)
Thanks for the offer!
Its a poor design, along with the C1 'single shear' clutch linkage setup.
But some think GM engineers could do no wrong; not true...
Now, I have worked on the same shock mount 4 times. Its frustrating! This weekend, I need to drive the corvette. I ordered another one just waiting for the part to arrive.
Sorry, I could not find any spares.
Good Morning,
I found this one, hit it with the blaster quickly, and it doesn’t look bad other than what appears to be a grinder hit. You are welcome to it. PM your address and I’ll get it headed your way.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Just curious how you found it? What was your car doing as to notice it?
I am wondering if the shocks were bottoming out (and bending the shock mount) when you had the other (lower?) springs in there.
I still have the originals, with stiffer shocks, and have not had any issues.
Plasticman
Plasticman
