Interesting transmission factory video.....
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
I don't know the make or company but it's interesting to see the assembly process.
One thing struck me.....the units are completely dry assembled.
I would have thought they would use some sort of assembly lube on the gears and bearings at least.
The following 4 users liked this post by Kerrmudgeon:
Kerrmudgeon (05-01-2018)
Thanks for the video...but spent more time looking at your avatar....
My very wise step-grandfather put me on a factory assembly line when I was 16 (during summer vacation)....I learned real quick that I could never do that type of repetitive work.....would drive me bonkers (and I would be assembling it in my sleep).
Plasticman
Plasticman
I want to be the official pan bolt installer! Good video
That film's a good argument for getting an education.
Received 2,127 Likes
Yup! I worked in a cannery the summer after having a tough time academically my freshman year in college. That convinced me to go back, do better, and get my degree - it was one of the best life lessons I ever learned!
I could see where any lubricant would really make a mess of that assembly line in a no time at all. Not to mention how slippery those little parts would be!
A shot of fluid into the cooling line probably was the final step.
All of the companies are using robots more and more so when they put everybody out of work , who is going to have any money to buy their products ?
Interesting - thanks for posting. I decided about a year ago that if I was ever going to rebuild a transmission I needed to get with it before I got too old. So I started on an A727 Torqueflite - which admittedly is no where near as complicated as those in the video.
This was not a simple weekend pull it out, shove a few seals and gaskets in it and put it back in. I spent about 2 months going over every inch of every part in the thing including a valve body kit, sleeving a servo bore, replacing a planetary, bushings, seals, converter, pump innards, measuring everything 2 or 3 times over. Filed all gasket surfaces flat. Worked great when I reinstalled it and doesn't leak a drop. But when I was done, I still don't think a week later that I could give an intelligent explanation on how it operates without resorting back to a service manual. Automatics are really a pretty amazing piece of machinery.
Next I did a Muncie M22 wide with new Autogear case and now I'm on my 3rd one - rebuilding a Toploader 4 speed. If you like tinkering with things and seeing how things work, rebuilding a transmission is a pretty do-able job and rewarding.
Received 2,827 Likes
Crowd Plow For Now
UAW wages can still get you a decent standard of living in Kokomo, In. There's a labor shortage and some midwest towns like Hamilton Ohio are offering $5k incentives to get people to move there.
