'65 L75 Fuel pump steel inlet line fitting removal - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 05-15-2018, 10:45 PM
C2 Jeff
CF Member
C2 Jeff's Avatar
Default '65 L75 Fuel pump steel inlet line fitting removal
Guys..I'm out if ideas... I'm trying to remove the steel fuel pump inlet line, connected to the brass elbow on my 300 HP '65
Whether it's from the top, bottom, or thru the wheel wheel, I cannot get any wrench on the fitting to turn it...
My last resort is to try needle nose locking pliers from the top, I'm just not sure I can get enough torque on it...I have to be missing something... any ideas?
C2 Jeff is online now
Old 05-15-2018, 10:59 PM
Critter1
CF Senior Member
Critter1's Avatar
I wonder if the pump and fuel line could be removed in one piece? (disconnected from the fuel filter) Once the assembly is on the bench, it would be a lot easier to separate the line from the fitting.
Critter1 is offline
The Following User Says Thank You to Critter1 For This Useful Post:
C2 Jeff (05-16-2018)
Old 05-16-2018, 06:29 AM
R66
CF Senior Member
R66's Avatar
Have you tried a crow's foot?
R66 is offline
Old 05-16-2018, 06:54 AM
Frankie the Fink
CF Senior Member
Support Corvetteforum!
Frankie the Fink's Avatar
If its that tight and difficult to get to and you can't get a "line" wrench on it then that's a problem -- nearly anything else will strip it.
Sometimes its just easier to cut the darn line close to the inlet and get a new one..
You can spend another couple of hours pizzing yourself off wrestling with it or cut the line and move on with the repair...
[rant]
Why people want to crank down on fuel lines like there is no tomorrow and distort things so the next poor soul can't get them loose is beyond me...
[/rant]
Frankie the Fink is offline
Old 05-16-2018, 08:21 AM
C2 Jeff
CF Member
C2 Jeff's Avatar
That might be an idea... The steel inlet line is short, maybe 4 inches or so and then there's rubber hose that runs from that to the steel tank line.. although a PITA to remove the fuel pump just to replace a bad line, it may be just worth it.
The car is at my buddy's garage, I'll take a look on Thursday.
Old 05-16-2018, 08:24 AM
dkleather
CF Senior Member
dkleather's Avatar
2016 C2 of the Year Finalist
Iím a bit unclear. Is the problem youíre having that the fitting is tight or you donít have room to get a wrench on it. When I put my pump on, I spent a few hours just trying to get the forward bolt lined up and in. Finally took off the lower radiator hose and gave myself the room needed. Minutes later it was bolted on.
I know youíre not trying to install a pump but is something restricting your access to the fitting? Dave
dkleather is offline
Old 05-16-2018, 08:28 AM
C2 Jeff
CF Member
C2 Jeff's Avatar
Yes. that and a line wrench with a swivelling head.. just not enough straight-on room...
Old 05-16-2018, 08:34 AM
C2 Jeff
CF Member
C2 Jeff's Avatar
Don't have room to get a wrench on it...only the 250HP and 300HP SB's have this short steel line attached to an elbow which is attached to the pump.. all the other small blocks use a rubber line
The best advice so far might be to drop the pump, and leave the short line attached to it... not sure if there's enough room, but I think there is...
Old 05-16-2018, 10:47 AM
Critter1
CF Senior Member
Critter1's Avatar
Is this the line/fitting that you are trying to remove?
Critter1 is offline
Old 05-16-2018, 11:10 AM
C2 Jeff
CF Member
C2 Jeff's Avatar
That's the one! But with mine, the fitting is on the other side of the pump.. left side...
If it was like the picture, I think I could get it off
Old 05-16-2018, 11:48 AM
hedgehead
CF Senior Member
hedgehead's Avatar
Location: I'm not doing as well as I expected, but I never expected I would
I there room to come straight down with vice grips on the vertical?
hedgehead is offline
Old 05-16-2018, 12:09 PM
Critter1
CF Senior Member
Critter1's Avatar
This may be a good opportunity to install the correct fuel pump.
Critter1 is offline
Old 05-16-2018, 12:44 PM
C2 Jeff
CF Member
C2 Jeff's Avatar
I just ordered one from Long Island Corvette,,,,This one has less than 300 miles on it as it was replaced in NJ by a garage when the running pump died on the way back from a show.
I'm still gonna try to just remove the line..if I have to pull the pump, I'll replace it with the new one.. otherwise , it will sit on a shelf.
Old 05-16-2018, 01:09 PM
dkleather
CF Senior Member
dkleather's Avatar
What do you want to accomplish by removing the steel line? Is it leaking?
Old 05-16-2018, 01:15 PM
C2 Jeff
CF Member
C2 Jeff's Avatar
Yes...at the fitting.. and also the steel line was partially crushed, probably by the garage who installed the pump
The Following User Says Thank You to C2 Jeff For This Useful Post:
dkleather (05-16-2018)
Quick Reply: '65 L75 Fuel pump steel inlet line fitting removal
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
