Cleaning old parts?
2019 Corvette of the Year Winner
St. Jude Donor '15
Cleaning old parts?
When you clean old parts what are some of your methods?
Mine? Parts I can fit in a can of carburetor cleaner go in there for a few days and then after wiping them down get a final wipe/dunk with acetone.
Bigger parts I use degreaser cleaners you can buy at auto parts stores and use a rag or wire brush on them.
So what do you do?
So what do you do?
Its hard to beat a media blaster... I've used a friend's a few times and its quick, does an outstanding job and is kinda fun actually... Best to degrease the part first so it doesn't assimilate into the media as much...
firstgear (05-17-2018)
St. Jude Donor '15
Roger that.....I have one of those too, but really need to make sure the air coming in is dry, otherwise they are a PIAto use...
The following 2 users liked this post by AZDoug:
firstgear (05-17-2018),
new vette 62 (05-17-2018)
Hard to beat beat blasting with the right media. I also like removing rust (not badly pitted and flaking rust) on small parts using electrolysis. I have watched videos using evapo-rust (sp?) but know nothing about it. And, if you have shabby looking driver quality or worse chrome parts try rubbing and polishing with a wad of aluminum foil.
firstgear (05-18-2018)
St. Jude Donor '07
Herb
using the top one at the moment. not sure what, if any, difference there is between the 2 brands. I bought 2 5 gallon cans of the top solvent and the bottom one was given to me .
got it at Tractor Supply
Bill
Bill
firstgear (05-22-2018)
I use fuel oil in a 35 gal. container with a basket strainer. I add 5 gal's of dirty lacquer thinner once in a while that comes from my spray gun cleaner.
I leave the part in as long as I can so that it does not require much scrubbing.
If long enough,(2-3 weeks)the paint will also come off.
About once a year. I pour off most of the liquid and take the sludge out of the bottom.
Soaking parts in red vinegar does wonders for rust removal as well as cleaning up anodized parts.
Received 2,130 Likes
2015 C2 of the Year Finalist
Use white vinegar 50-50 and a sheet of news paper to clean glass. Use apple cider vinegar in everything, dressing, sauces, marinade, mouth wash, great stuff, probably among God's best gifts to humankind, right up there with Corvette.
Dan
Dan
Degreaser - mini or regular size plastic garbage can - 7 to 10 scoops of Tide detergent - roil with full stream from garden hose, filling to full coverage of the parts to be cleaned - deposit parts - wait two or three days, remove parts - flush with hose - roil detergent with stick, replace parts, add detergent and water, wait two or three days - You'll send Tide a letter.
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I've used my soda blaster ($75 from harbor freight) on a lot of parts to clean them up.
Everything from the intake manifold, hood pins and latches, the wiper motor case, even the finned valve covers.
Works very well... but too much baking soda can kill grass (ask me how I know!)
apple cider vinegar, red cider vinegar. I set small items in a container of it for a day or two and any residue or rust will wash off easily with a soft brush and water.
Works great for small parts like hood latches, brake brackets, nuts and bolts, hood props, hinges, strikers, etc. And it can be reused several times.
