Question 67 SB shielding
Has anyone here ever seen this type of shielding ?
That isn't C2 small block ignition shielding. The piece covering your distributor appears to be C3 1970-1974 big block ignition shielding.
Jriver (05-24-2018)
It is a 70-74 top box, but it wasn't limited to big blocks. That top box was used on both big blocks and small blocks. Normally a small block would have the vertical side shields installed too. Big blocks use different support brackets.
Jriver (05-24-2018)
This is typical small block shielding.
Jriver (05-25-2018)
