Rochester FI ????
Received 1,283 Likes
Keep those ideas coming.
Remember, this is a 300 hp engine, and I am NOT looking for significant horse power increases.
I am looking for increased reliability and starting / running ease, as well as "the look".
If I can get a system that gives me the same horsepower performance, with the EFI reliability, I'm all in.
Jim,
I think some form of nozzle would be necessary to atomize the fuel when it is injected into the air stream. With a single big injector firing into a central chamber of the spider the correct amount of fuel will be delivered but it would still be in liquid form in the spider tubes.
Received 6,527 Likes
C2 of Year Finalist (track prepared) 2019
Jim,
I know Rochester FI backwards and forwards. EFI.... well, I know only what I've read.
Even goofy ideas sometimes lead to brilliant ideas.
Keep those ideas coming ya'll.
I have made a deal for a 64-65 plenum with welded up legs.
I am still looking for a lid and a baseplate.
All leads gratefully appreciated.
I gotta million of'em.
Instead of cluttering the inside of the plenum with nozzles and other stuff which could impede air flow, do this:
Punch a couple of holes in the floor of the plenum and mount a pair of upward pointing nozzles which can spray fuel into the plenum. Locate one nozzle near the forward 4 ram tubes and the other near the rear 4 ram tubes.
jerry gollnick (06-20-2018)
Which gives me an idea, what about modifying the inside of the plenum so that it literally becomes a dual throttle body arrangement?
Another question...
Has anyone ever considered / tried to "make" a baseplate / manifold for a Rochester FI system by cutting down an aluminum intake manifold of some sort, even a old GM vintage intake?
I recall seeing a 63-65 Rochester FI on a big block chevy many years ago. Kinsler used to make the manifold plate for that.
welded plenum
Just a suggestion. You will want to very carefully examine the welds on your new plenum. Have it dye penatrant checked. Mine had some cracks and I had true expert help to fix it. My golf partner was an RPI graduate metalugist/welding engineer and president of the LA chapter of the American Welding Society. The welder was an aluminum TIG expert and the two of them spent a full day repairing two small cracks. The casting metal is very dirty and they used every trick in their bag to get good sold repairs. It's still perfect 35 years later.
Not sure I follow, Ed. Are you proposing to put a divider in the plenum, making two chambers?
#33
St. Jude Donor '07
there is not much room inside the plenum, and I wouldn't recommend cutting down the risers as this is what gives the 'ram' effect and low end torque.
an EFI throttle body mounted in placed of the airmeter is a possibility
Bill
Bill
#34
What about simulating a cross fire injection setup.
Use two injectors mounted inside the plenum, each one centered over the 4 intake runners.
Something like this...
And while I am thinking about it, does anyone have a good picture of the inside of a 63-65 plenum. There was one posted a while back that had rulers on top of it for specifications. Any chance of getting another picture without the rulers.
#35
St. Jude Donor '07
injectors plus the caps are pretty long (although there are some shorties…), I don't think you have enough room above the runners without cutting them down (which as I said, I wouldn't do...)
Bill
Bill
#36
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
The "limitations" reside in our own minds.
#37
I agree. Cut the runners and you lose noticeable mid-range grunt in exchange for questionable benefit north of 8000 RPM.
#39
Received 1,120 Likes
2017 C2 of Year Finalist
I posted these photos earlier, but it shows what I intended to put together for my 63. Only thing lacking in these photos are the fuel lines. You may note that I altered the plenum holes to accept injectors. The blocks you see in the photo are to hold down the injector, feed fuel from the fuel tubing, and hide the wiring. The blocks will be painted black to look like the original ones and are held down by a double ended stud that threads into both the block and the plenum's existing 1/4 hole. I've thought about using the air meter and adding sensors to it, but that would ruin good air meter, so I got a stock throttle body and fabbed an adaptor. It uses a FAST EZEFI multiport system.
Right now I planning to assemble it all on the 383 I'm building.
emccomas (06-19-2018)
#40
St. Jude Donor '07
I posted these photos earlier, but it shows what I intended to put together for my 63. Only thing lacking in these photos are the fuel lines. You may note that I altered the plenum holes to accept injectors. I blocks you see in the photo are to hold down the injector, feed fuel from the fuel tubing, and hide the wiring. The blocks will be painted black to look like the original ones and are held down by a double ended stud that threads into both the block and the plenum's existing 1/4 hole. I've thought about using the air meter and adding sensors to it, but that would ruin good air meter, so I got a stock throttle body and fabbed an adaptor. It uses a FAST EZEFI multiport system.
Bill
