Rochester FI ????
#42
Received 1,119 Likes
2017 C2 of Year Finalist
You can't see it in the photo, but there is now a lever in place of the cable mount on the throttle plate stud. (the throttle body is actually going to be mounted 180 degrees from its orientation in the photo, so the lever is on the proper side to work with the current linkage). It actually works quite well with the original linkage and the bellcrank that mounts on the stud you see still attached to the plenum.
#43
Received 1,283 Likes
I posted these photos earlier, but it shows what I intended to put together for my 63. Only thing lacking in these photos are the fuel lines. You may note that I altered the plenum holes to accept injectors. The blocks you see in the photo are to hold down the injector, feed fuel from the fuel tubing, and hide the wiring. The blocks will be painted black to look like the original ones and are held down by a double ended stud that threads into both the block and the plenum's existing 1/4 hole. I've thought about using the air meter and adding sensors to it, but that would ruin good air meter, so I got a stock throttle body and fabbed an adaptor. It uses a FAST EZEFI multiport system.
Right now I planning to assemble it all on the 383 I'm building.
#45
No vehicle experience yet, but the linkage seems to be smooth enough. We'll see...
Opening up those holes in the plenum was not fun, not really very accessible from above...
#47
I agree with Bill, the throttle linkage is very fiddly to get smooth. Because the throttle body spacer moves the pivot point outward I fabricated all new stainless linkage, thottle arm, bellcrank, links and mounting stud keeping the original geometry but spaced out the thickness of the spacer. I used the LS dual hairpin return springs so I didn't have to fiddle with the return spring arm on the new bellcrank. I used oilite bronze bushings to smooth the pivot. The final bit to get it smooth is a slight twist on the throttle body arm just like is found on the original air meter.
Vettrocious this may have fallen through the crack earlier but you can backchamfer the injector bores to protect the orings by finding a woodworking dovetail cutter and making a sleeve that centers the cutter in the injector bore. Chuck it up and gently pull it back from the bottom. The cutter angle is a bit off from ideal but you get a smoothed entry for the orings.
#48
Grampy, I made a special tool that I inserted from above. It had a flat cutting surface to get a step in the hole. I found that trying to drive it with a drill on my test pieces was very difficult in aluminum, so I ended up turning by hand. I can make a similar tool with an angled cutting surface to cut the chamfer. Thanks, Mike
#52
And so I am beginning to wonder if I might be better off buying a complete 63-65 Rochester FI system, pulling off the parts that I want, and then selling the rest of the parts.
There seems to be a good size market for 63-65 FI parts.
Perhaps if I started with a "complete" 63-65 FI unit that does not have a distributor or air cleaner assembly, and may also be a mix of parts from various years.
So let me take a stab at this idea.
Lets say I pay $6K for a complete FI system that is working, but doesn't inc'lude a distributor or air cleaner parts.
Lets also say it is a mix of 63-64-65 parts, but that all of the parts are in decent restorable (not broken, cracked,. etc.) shape.
Now, I will keep the intake manifold / baseplate, the plenum, the plenum lid, the fuel meter housing, the air meter "housing".
I would also possibly hold onto the spider, nozzles, and nozzle blocks.
All of the other parts would be up for sale.
Can anyone take a wild guess at what the remainder of the parts would be worth?
#53
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
IFFFFFF you keep the parts you named......................what parts are left to sell?
Just asking.
#54
All internal parts of the Air Meter
All internal; parts of the Fuel Meter
Choke assembly
All of the tubes, lines, etc.
The Air meter external parts may not be needed, so that whole assembly may be available
#55
Don't know, because I don't know what parts constitute a 63-65 FI system.
Choke assembly
Choke assembly
Good luck with whatever you decide.
Rex
#56
And now I am sitting here thinking that if I buy a complete unit, I might as well get a correct complete unit, and put that on the car as is.
Yes, I know that was suggested many posts ago.
Sometime I have to go across the south 40 to get around the barn.
Yet another idea.
Ok, so what am I looking at price wise
1. EFI system like a Holley Sniper - $3K all in?
Works OK, reasonably cost effective, does jnot look like much.
2. Modified Rochester FI to EFI using 63-65 parts - $6K all in
Works OK, a bit on the expensive side, looks cool
3. Modified Rochester FT to EFI using 57-62 parts - $5K all in
Works OK, still a bit pricey, looks out of place
4. 65 Rochester FI, restored, running, no air cleaner - $10 all in
Works OK, serious money for a non original FI car, looks cool
Do these prices seem reasonable approximations to ya'll?
Yet another idea.
#58
Received 6,519 Likes
C2 of Year Finalist (track prepared) 2019
As a rocket surgeon, as you study it's intricacies I think you'll be impressed and want to embrace it as is.
Jim
#59
#60
St. Jude Donor '07
It will definitely work, but it is definitely 'out of place'....
i'm with Jim, if gasoline wasn't so crappy i'd still be running my complete FI (I still have it in a box...), it is awesome. C2s seem to deal better with the perc problem due to their fuel routing to and from the spider....
needless to say, I built my system to retain the "look", but to circumvent the perc problem; works well for me (although I still haven't got it tweaked as well as i'd like)
Bill
Bill
