Rochester FI ????
#102
St. Jude Donor '07
No offense taken Bill.
We all have out opinions about these things.
If I had the air cleaner assembly, I might consider using it, but that still presents the issue of what to do with the alternator.
It could be worse, the first 63-65 FI unit I ever saw on a car was on a 1957 Bel Air Convertible. It had a custom air cleaner similar to the 57 air cleaner setup.
And the entire unit, including the air cleaner setup, was gold plated. Real gold plated, not painted.
I wish I had gotten a picture of that engine.
some ideas http://www.alangrovecomponents.com/S...Short_Pump.htm
Bill
#103
Received 1,843 Likes
[QUOTE=JF in MI;1597460679
There are lots of hot rods at shows that have been converted to FI (usually something off a new Corvette etc) but no one, that I've seen, daring enough to try a completely original Rochester unit.[/QUOTE]
Lot's of street rods had the Rochester FI on them. Take offs from Corvettes that had incompetent mechanics that didn't know an ignition problem from a fuel problem. Then, the price climbed of the Rochester's and the units came off street rods and back on Corvettes and/or Ebay.
I like what you've done there even though the throttle body system isn't exactly as responsive as port injection. I think you did a great job on your conversion and the Corvette people I know, most wouldn't know the difference and who cares if they do? Your's is probably the best one that mocks original I've seen.
I live and drive on Indiana/Kentucky gasoline and don't have much, if any problem with 89 E 10 gasoline. Maybe I am just a little more tolerant than some?
#104
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Saw this at Bloomington / Indy yesterday. Looks interesting..........................it' s for the LS engines.
#105
That is probably from the same vendor as other LS Rochester creations you can see on this website:
https://www.lsclassic.com/
#107
Hop, skip and a jump. Go see your neighbor for a few ideas.
http://www.superchevy.com/how-to/eng...1954-corvette/
#108
Received 1,283 Likes
#109
as a tinkerer to a rocket scientist, where there is a will there is a way... back when I added a/c to my 65 FI coupe in about 68, I nestled a York/Tecumseh style compressor on top of the intake manifold between the plenum/thermostat housing and the alternator. compressors are way smaller now....
Bill
Bill
No doubt that are many ways to do this. I just need to decide how far I want to take the idea.
#110
#112
2nd Gear
