[C1] 54 wiper / fuel pump/ vacuum issue
Old 06-19-2018, 08:40 PM
keeks2915
keeks2915's Avatar
Default 54 wiper / fuel pump/ vacuum issue
My brand newly rebuilt fuel pump is Making ticking noise and one minute 18 inches of vacuum and then the next 1 inch at idle.
Ticking noise goes away when at 18 inches, and wipers etc won't work on that fuel pump. But when we run direct vacuum line from my 69 C10 all components of my wiper system work.
And when we run wiper / Washer system straight off intake manifold vacuum it works perfectly.
So what we know.. 1) wiper motor, transmissions and Washer work as does wiper switch (when directly on intake vacuum or 69 C10 vacuum connection. 2) previous fuel pump worked well on fuel side but pushed pressure instead of creating vacuum.
I am guessing my newly rebuilt fuel pump is hooped?
Old 06-20-2018, 07:44 AM
csherman
csherman's Avatar
Received 1,421 Likes on 734 Posts
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
do you have the lines mixed up
There are two lines on the bottom of the pump
easy to get them mixed up......
Old 06-20-2018, 08:24 AM
keeks2915
keeks2915's Avatar
The entire system functions correctly and perfectly when then the wiper motor receives vacuum directly from port on the intake manifold or from and independent source like the vacuum I connected off my 69 C10 I parked beside the car.
Would the system function perfectly with these vacuum sources if I had the lines mixed up at the bottom of the pump itself? As I am hoping its that easy and I'm that stupid...������
Old 06-20-2018, 04:42 PM
Randy G.
Randy G.'s Avatar
The vacuum pump on the fuel pump has two one way flapper valves that work together to create vacuum. If one or both is leaking then it won't hold. Same if the diaphragm is torn or leaking. I went through that with mine. I bought a rebuild kit for it and it was a waste of time and money. I ended up getting the fuel/vacuum pump from a rebuilder, and I posted the results on youtube.
Old 06-20-2018, 05:47 PM
keeks2915
keeks2915's Avatar
As usual the legend of Mr. Sherman gets the prize. I feel like such an idiot!
The following 2 users liked this post by keeks2915:
csherman (06-25-2018), Randy G. (06-21-2018)
Old 06-25-2018, 08:22 AM
csherman
csherman's Avatar
Hey - looky there - I was right for once !!!!
To 54 wiper / fuel pump/ vacuum issue
Quick Reply: [C1] 54 wiper / fuel pump/ vacuum issue
