[C2] extra cooling radiator fan shroud?
The radiator fan blades stick out of the shroud by an inch or so by design. Is there a particular reason for this? Would air pull increase by extending he shroud? Just an idea....
Received 6,928 Likes
2015 C2 of Year Finalist
It’s designed to be half in. Or half out depending how you want to look at it
wmf62 (06-24-2018)
that makes sense. Next question: I assume the 67 extensions do not fit my 64 shroud? (although it does have what seems to be screw holes in it, and it's brand new...)
Larry
alexandervdr (06-25-2018)
If you are looking for more airflow through your radiator, have you gone to the 7-blade fan made for the '64-'65 A/C cars? Another alternative would be the '66-'67 fan for A/C cars, which had only 5 blades but a steeper pitch angle.
DR REBUILD at one time sold a kit to add a rubberized extension to the earlier AC cars. Not certain if the factory did this or not for early AC cars (probably did) but he offered one. I helped one of the CF members on how to buy and install it a few years back. So it will be in the archives. I want to say his CF name was CAPEVETTES, or similar. The DR part number was/is 1274201. Requires attachment with staples, which are available #1274014.
Larry
Larry
Received 3,443 Likes
If you have your fan all the way in the shroud, you will get less cooling than half-in, half-out. Due to turbulence. There's a reason the engineers place the fans where they do (half in, half out) on pretty much every car and truck with a mechanical fan and a shroud. Whatever shroud you 'upgrade' to, be sure to have the fan half and half.
I think if you look at the fan placement, it will still be half and half even with the extensions. From all my experience in the auto industry over the years, installing a fan all the way in a shroud is a no-no. You can go online and google it, etc. It is counter-productive due to leaving nowhere for the turbulence to go....it tends to trap hot air in the shroud rather than pulling it all through the shroud. Sort of like water cavitation....
in aerodynamics, few things are 'obvious', hence sometimes very conflicting points of view. I happen to have spent zillions of hours researching small sized propellors and turbines. My findings were that a fan shroud COULD (and most of the time will) enhance flow, but only if the tips of the fan blades are close to the shroud. That is not the case in our cars. Blade tip turbulence spoils the party with increasing tip to shroud gap. That may indeed be one of the reasons why the blades are 1/2 or 1/4 out, the air on the tips is thrown out and by doing so streamlines the turbulence.
Nothing beats trying things out though, so when time allows I will mould a shroud extension and see what happens
Received 1,283 Likes
Here is a picture of the 66 AIM showing the "Fan Ring". Wasn't factory on 65 and earlier cars, but sure looks like a good idea.
Also sealing the upper and lower radiator areas like the AIM calls for with big block applications isn't a bad idea.
JV04:
!965 and earlier C2 cars have a different (metal) fan shroud. As such, the 66-67 lower shroud extension will not work for them. That is why I gave the OP aftermarket part numbers for a shroud extension that would work correctly on his car........although the extension is a rubber fabric and not fiberglass/plastic.
Larry
Larry
JV04:
Larry
Larry
