Drill older shift levers for short throw?
Received 5,009 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
I'm getting way ahead of myself, but I'll ask now anyway. When the time comes to put the '64 on the road, I'd like the short-throw setup on the shifter. Can the original levers be drilled to create that result, or it it better (or necessary) to buy newer levers? Is there a template or diagram of where to drill?
Received 1,843 Likes
I would imagine those shift levers are very hard steel.
Zip has them for 12.99 ea, I'm sure others do too.
https://www.zip-corvette.com/64-68-4...r-1st-2nd.html
https://www.zip-corvette.com/64-68-4...r-3rd-4th.html
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
Received 1,857 Likes
Those levers are the hardest steel I've ever worked with - if you plan on drilling them, hope you have LOTS of cobalt/titanium drill bits. Hint: The drill bits will cost at least twice the price of buying the levers ready-made.
Railroadman (06-26-2018)
So is it just change the brackets and reconnect the adjustment rods to the lower holes. Or is there a science in adjusting the rods to make it shift correctly?
Also how much is the throw reduced?
Put it in neutral, remove the rods and levers, put the new levers on, adjust the rods to fit the other holes without moving the levers. It should be right. If not, you can always put the adjustment tool into the slots and touch it up. It should be right when you hook it back up as long as the levers stay in the neutral position.
Don,
When I had my 63', I changed the stock shifter with a Hurst Competition Plus shifter. The throws were sharp and crisp and precise. It was a great addition to the sloppy, rattling shifter, that, I had.
What would have been the result if you had replaced your worn out, sloppy, rattling shifter with a brand new original? Just curious.
I used carbide drills and carbide taps to reassemble a demilled Browning 1919 BMG using button head socket cap screws, rather than use rivets like original. The side plate on the BMG are EXTREMELY hard steel and laugh at cobalt drill bits. Yes, i have the proper license to build machine guns.
Doug
And, as is today with newer cars, people seem to think that after market or speed stuff is better than stock equipment.
I recall back when I had my '67 I changed it to the short throw. Can't say just how much it changed the movement but I recall liking the feeling. John used the word "crisp" for his Hurst, and that's how I remember the stock shifter when I did this. Of course at the time it was a 2-year old car.so you would HOPE things were still tight.
As for the rattly '63 John, IIRC the '63's had the shifter mounted on the tranny, but later years were mounted to the frame and were less prove to vibration. Someone please correct me if I have that wrong.
