lead additive in 1967 corvette
I'll throw myself on the fire and be the contrarian.
I run lead additive. I use "Octane Supreme", which is the only product, as far as I know, that actually contains lead. The plastic bottle stuff carried in auto-parts stores do not.
There are many stories of "no problems".. I get that. But for some reason on this forum, the powers-that-be approve of ZDDP, and disapprove of lead additive..Even though both recreate the original conditions that our motors were designed for. I don't quite understand the logic.
Anyway... do your own research.. There are plenty of stories of documented destroyed valve seats out there due to unleaded fuel.. with tear-down photos..
And welcome to the forum.. You just happend to choose a highly debated issue as your first post!
Tetraethyl lead was originally added to gasoline for two reasons:
1. It allowed higher engine compression with then known engine/mechanical technology
2. PROFIT $$$$$$$$$$$$$$$$$$$$$ for the oil companies and for GM (GM developed TEL, and Ethyl Corporation who first manufactured and sold it was a joint venture with GM and Exxon Oil)
The positive effect on reduced valve recession and valve life was an unintended consequence. And this effect was only significant during high load engine conditions. Our classic cars don't qualify.
Larry
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Larry
Larry
St. Jude Donor '07
Larry
Larry
but you might as well p into the muddy Miss in hopes of clearing (not cleaning) it up as to try to change madeup minds. it's their $ and if it makes them feel good (Frank's offer aside...), so be it....
Bill
btw, we were in NOLA for a medical conference a couple weeks ago, toured the Destrehan Plantation across from you; Tara it's not, but it ain't Georgia either. Mississippi is a whole different environment and culture
webfiero (07-19-2018)
Larry
Bill
Bill
You should have called/emailed and come by the house. We could talk MOPARS and Cogen.
Larry
In my mind, this driving is stressing the valve-to-valve seat interface. Without a layer of lubricant, the very high temps and metal-to-metal contact are exactly what cause seat recession.
And yes, it's not uncommon to climb 4000-5000 feet on a drive here in SoCal.
Never take long highway trips? Probably fine. Have overdrive to lower the RPM? Probably helps a lot.
I'm just not taking any chances. No one has commented on the links I posted. These are real car guys tearing down their engines to find valve seat damage.
Not anyone selling products or services. Who has the closed mind?
Why not just run 100 octane leaded fuel?
Falcon05Dad (03-22-2024)
#33
My dad was a private pilot. I know the drill.
It's also about $6/gallon.. Cheaper to use a few ounces of Octane Plus per tank.
#34
I know the drill, too. I fly almost every day. All you have to do to get a key card is to ask and have some sort of half assed reason. It is never a problem getting on an airport. If they use keypads just tell them you are picking someone up. Once you know the code you can't unknow it.
#36
Received 2,128 Likes
2015 C2 of the Year Finalist
Here ya go.
The car potions (additives-supplements-cleaners) are not unlike nutritional supplements and vitamins. There are piles of research to advocate for both, and many people say thy feel better when they take them; and that their automobile runs better when they use them. As such, who gives a damn whether the science behind it is real? If it feels good, do it. None of this crap hurts anything as long as you don't put too much in the wrong hole, just like vitamin C and low gluten yogurt.
Dan
Dan
#37
Here ya go.
Dan
Dan
Interesting analogy, but you're generalizing widely. I don't use it to feel good. I don't use any other 'potion' type car products, and I don't take supplements or vitamins. I use it for a specific reason.. The reason is this: The gas from the pump included TEL when the car was new. The TEL performed a function (valve seat lubrication) that extended engine life. When gas was changed to unleaded, valve seats in new cars were changed (hardened) to accommodate the lack of TEL in the fuel.
It's exactly the same for ZDDP levels in oil. They have been reduced over time, and engine design has changed to accommodate the lack of it.
OK, I think I got this out of my system. I'm off to fill my crankcase with Pennzoil 10w-30 and sign up for Frankie's protection plan. Good night gents!
#38
I add zddp at every oil change. My camshaft lobes and my tappets are very very happy. They measured up well within tolerances at the last tear down for repaint and looked as new. Is it due to the additive? Can't say for sure. But what I can say for sure is that the extra $5 at every oil change will continue for me.
#39
Received 3,043 Likes
St. Jude Donor '05
IMO works better than mixing ca 91 and some VP 100 plus it costs way less.
Yes you can get valve recession...got it on my 67 rs, orig seats. was a daily driver. Didnt tow with it. Would leaded gas make it last forever, no.
Those seats are how many yrs old, if they are getting beat up replace or buy new. Not a big deal for something either way thats seldom driven.
#40
Received 1,843 Likes
