[C2] Elecrical issue on my 67
I'm gonna say this and hope I'm wrong - if its one fuse holder the stopgap above might work; it its corrosion then you MIGHT be able to clean things up....if the fuse holder fingers are weak AND there is corrosion you might be in for a wiring job. I played getting this 67 Chevelle fuse box working consistently for about 4 months before I threw in the towel and replaced it. Doesn't look that bad ? Right ? Wrong. nothing but problems...you can see the corrosion on each fuse holder.
I'm just sayin'
I'm just sayin'
