LS swapping my 64 coupe
Received 5,547 Likes
Ah, what a glorious project!
Best of luck with it and thanks for bringing us along.
Oh, and so far you are right on schedule.
13joneje (07-16-2018)
I had replied in your other thread and I am converting my 64 over to disks as well. My trailing arms were ok,(maybe) but I'd rather just get new everything & not worry, so I went thru VanSteel & did the full conversion thru them. Dual M/C, all new lines, frt & rr disks, along with the offset trailing arms that allow for a wider rear tire.
day 2 update:
- Got the new fuel tank and lines put in the car
-unboxed the engine and transmission to test the fitting
-begin removing the steering box and steering.
also today i ordered a digital gauge cluster and wilwood front brake kit with master cylinder and everything to use the new front disc with the original drums in the rear. I plan on keeping the original wheels that are on the car but probably changing out the tires. Im still waiting on a tilt wheel steering column and adapter for the original steering wheel. steeroids rack should be here tomorrow so i can get that installed while the engine bay is clear. she is coming together pretty quickly. i believe that i have all of the parts that ill need. Just have to get the headers made so i can tie them into the sidepipes.
nice !!!
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
In post 27 you showed a pic of the new Van Steel trailing arms and they have disk, so you will have disc's out back, right? Also, you ordered the whole enchilada from them so you don't need anything from Wilwood.
You should check to see if your wheels will clear the calipers - I would be surprised if they did.
#33
C2 of Year Finalist (performance mods) 2019
St. Jude Donor 03-'04-'05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I would slow down.
13joneje (07-17-2018)
#34
#37
That was my post, and you had me worried, so I checked the rear, by placing the Right Rear caliper on the passenger side trailing arm & it has over 1/4" clearance to the bolt on reproduction 64 Corvette America rim.
I need to confirm clearances on the front as well...
#38
So I just assembled the fronts & confirmed they do fit as well. Very close as shown in the pics, less than 1/8", and I think i will clearance the corner of the caliper a touch, it is not in a critical strength area, and being a lifelong automotive engineer dealing in custom builds, it'll be fine...
I used the Green Marker to show where it got close, looks like i can just round off the corners here.
#39
Originally Posted by Rob_64-365;159761830[i
Just round the 2 corners a bit marked in green.[/i]
#40
Just the arm shape is different, the spindle doesn't move in or out, as a wider tire would hit the stock trailing arm before it would contact the wheelhouse inner. Do a search, it's widely discussed what will fit after.
