Silicone removal?
Silicone removal?
One of the bubba’s that had this car decided to use a whole tube of silicone to hold the passenger window to the window frame. I managed to carefully slide a razor blade down each side but the bottom is really stuck. Should I squirt some 3M adhesive remover along both sides hoping it will soak to the bottom? Any ideas or advice are definitely welcome.
elwood13 (07-16-2018)
Before you take it apart, put a few witness marks on the window frame where it attaches to the window mechanism. When it comes time to reset the window with the correct window tape, you won't have a problem with the window tracks. I had to perform a do over to center the window correctly. Jerry
Like lacquer thinner mineral spirits will soften silicone.
