Who has the best upper-outer shaft for 53-62 front suspension
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
At some time in the past, someone here posted a comparison of upper-outer eccentric shafts for the 53-62 upper A-frames. One of the shafts had a more pronounced eccentric than the other.
Well, I cannot find who provides the shaft with the more pronounced eccentric, but I know someone here has that information. I'd just like to know where to find those upper-outer shafts.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The upper outer is usually not an issue, the upper inner on the other hand is... The imported version of the upper inner shaft is not correct.
I would never want, nor would I install an upper-inner shaft that just screwed right into the the threads that the original shaft came out of. These shafts are supposed to be so tight that there would never be any possibility of them turning in the spring tower.
When on old shaft is removed (hopefully it is tight), it is not uncommon for the shaft to be a little loose in the threads in the spring tower. When a new replacement shaft is installed------------------IT SHOULD BE VERY HARD TO SCREW IT INTO THE THREADS IN THE SPRING TOWER! You want that shaft to be TIGHT!!!!!!!!!!
There have been times that the spot welded bushing in both sides of the spring tower has become too enlarged for even an oversize shaft to screw into and fit tight. There is a fix for this. Paragon (the only source I'm aware of) sells new replacement threaded bushings for replacing the worn out original ones in the spring tower. The originals were spot welded in and to replace them, DRILL, DO NOT CUT, the spot welds and then tack weld in the new ones.
Just like from the factory, the replacement bushings have a smaller threaded hole on one than on the other-----------------THE SMALLER THREADED HOLE GOES TOWARD THE REAR!
Former Vendor
REPLACEMENT upper-inner shafts for 53-62 Corvettes and 49-54 Chevy pass cars is SUPPOSED to be oversize.
I believe and I've not checked, but I think they indexed 1 1/8 from the outside edge of the tower insert to the end of the shaft and this is critical too. Complete front suspension installation instructions from the factory service manual can be found at this link http://repairs.willcoxcorvette.com/w...-From-ST12.pdf
Upper Eccentrics
DZ, is 100 percent correct, Paragon is the only company that makes the tower washers... And over the years I've seen the upper shafts welded in place, or just loose in the tower washer. The only correct way to replace them is to remove them and install new. My post was just to point out that the imported upper inner shafts suck... they are not correct and if you try to install one it will mess up your tower washer. They are the same size front and rear which is totally incorrect.
