1965 Vette Gets a Subtle Update
CorvetteForum Editor
By Brian Dally
Would you alter your dream car? See what the owner of this '65 did to his, inside.
By Brian Dally
yes i would ,and if i could find one with 2 cup holders i would do that too
By Brian Dally
By Brian Dally
Received 1,919 Likes
Your car is a work of art.
woodsdesign (08-04-2018)
This is very close to what I consider the perfect driver C2. First its a coupe with A/C. Second it has a reliable injected small block with more power than an original big block and a 5 speed (overdrive). And third better suspension. The only things I would do differently is keep the original paint color, swap in a set of widened 67+ rally wheels and find the widest UHP tires.that fit.Oh and maybe used an aluminum LS motor although that would ruin the looks.
Woods what EFI system is that? I have a red 65 coupe also. Added AC ,Van Steel suspension, TKO 5 speed and Mass Flo EFI.
For the last couple of years I have been running a Holley HP unit. It is fantastic. I would highly recommend it.
If you were at Corvettes at Carlisle 2018 I had the pleasure to view your car in person. Pictures do not do this car justice. It is absolutely gorgeous. Extremely well done and timeless. Very impressive to say the least.
woodsdesign (11-29-2018)
It's gorgeous. Are you using the intake manifold Holley sell with the complete HP kit? Where is the oil filler now? Also, is the "Muskegon" rear spring you are using the tapered composite that Muskegon brake took over from TRW? I didn't see any mention, but that dual master cylinder is an upgrade, too, if I remember things correctly.
http://www.superchevy.com/features/1...-panic-attack/
C2 of Year Finalist (performance mods) 2019
St. Jude Donor 03-'04-'05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
You have a great looking car.
The cup holder might be in the way when shifting gears. Needs to be a little lower. Also, the chrome lip flaked off on the one I had. I am returning it for a black one.
I have not had a problem with the chrome on mine. I have had it for at least 5 years now.
woodsdesign (11-30-2018)
Very nicely modded Sting Ray, woods. The original style engine looks so much more appropriate in a C2 than an LS motor. Congrats on creating a work of art!
