Electric Steering on a C-1
Anyone tried or read the article on electric steering adapted to a C-1 ? I had contact with owner of a 59 that retrofitted a steering control from a Saturn. Power steering without a pump, leaking hoses, or an expensive system alternate. One can still retain the huge steering wheel ( which adds to the classic interior ) and parking becomes a breeze . There was an article on HAMB but I could not find it.. Sounds interesting from a research stand point.
St. Jude Donor '07
Bill
I sold a 57 to a guy in Germany and he installed electric power steering on it. Used the original column, just had to cut it between the box and the firewall. I will see if I can find a picture of it for you.
Electric steering
The electric conversion is nice and provides variable assistance depending on the steering effort needed but it is pricey. If I had wanted power steering in my 61 I prob would have gone this route....it does require chopping the C1 steering shaft a certain amount and adds more clutter under the dash though... Never converted though - with the big steering wheel properly sized and inflated tires and a few steering techniques I taught my 110lb daughter to whip the car around with no problem.
Nothing is funnier than seeing some C1 owner trying to crank that big school bus steering wheel around to park at a DEAD stop with fat radial tires on the car.
Well maybe some "plus-sized" owner trying to do the same thing with a smaller 15" steering wheel replacement might be funnier.
Then they gripe about the old technology and how hard it is to steer..
Yeah you can give yourself a hemorrhoid muscling these cars around if you don't employ a bit of high-school physics.
It won't help sloppy components. When done properly, you can steer with 1 finger. Even when sitting still. There are other drives other than the Saturn that you don't need the controller, but the controller is nice to adjust the feel to how you like it. I built the complete unit for under $ 200. I have 2- 59's. 1 has stock steering & 1 is modified. I like driving them both.
solidaxel (09-19-2018)
Pro Mechanic
Received 1,299 Likes
2023 C1 of the Year Finalist - Modified
I have done this on a 59 Corvette a couple years ago. I got it on the road this year & works great. Be sure your steering box is good & front end steering, king pins etc are all good.
Here is a link to the controller on ebay
https://www.ebay.com/itm/Saturn-Vue-...LH_TitleDesc=0
You can get the power steering parts you need from a junk yard. I paid $ 40.00 for mine. be sure to have them cut the wires long & give you the wire plug, & the shaft splice parts.
I cut the corvette shaft in the engine compartment. It might fit under the dash, but its already tight under there. Both ends of the shaft housing are fastened to the steering motor, so you don't have to fasten it to the frame. I will see if I can find my pictures
JF in MI (08-05-2018)
Very clever if it works - but I'm also wondering how it works without an anchor point...
How can it assist anything just floating in space ?
It is really a motor assist instead of power steering.
This picture is from last year when I was testing it
Received 1,720 Likes
2018 C1 of Year Finalist
https://www.youtube.com/watch?v=NivxqlpVRMA
St. Jude Donor '07
Bill
C1 of Year Finalist (appearance mods) 2019
Does this require modifying the outer steering column housing to the point you have to remove the VIN data plate? If not, this is an interesting idea. In another discussion I was told the electric motor went under the instrument panel, yet hlvette shows it on the engine side of the F/W. Is this just another mfgs way of doing it?
BH
BH
