Air Bubble in 1963
#41
Received 5,554 Likes
When you park on a hill, do it sideways with the expansion tank at the highest point.
Best of luck!
Best of luck!
ricoman (08-10-2018)
#43
Received 1,843 Likes
N
...gauge will go back and forth from 180-260-200-180-260 and then back down to normal...assuming an air bubble in system...
....OR..anyone have any suggestions....dont want to use car with temp. gauge going crazy like that and possible engine damage...and..YES...its a new gauge,so thats not the cause...
As far as I can tell, you have never verified your engine is actually getting hot. You've just assumed it is because your newly installed temperature is waving at you.
I suggested way back that you let the engine idle with the cap off and if the temperatures were going as high as you posted, that you would be shooting steam out of the overflo tank with the cap off. Have you tried this?
I also suggested that even if you did have air in the system, after one or two hot/cold cycles of the engine will allow the coolant to stabilize and you should be able to top off normally, even if your heater hose T is on the wrong hose.
I further suggested that if you do have air in the system that won't go away, you could have compression leaking into your cooling system. An easy way to check for this is to remove the thermostat housing and thermostat and watch for a constant flow of bubbles coming to the surface.
#44
Alas I was incorrect on the Air cleaner base....It does indeed appear to be a 63 base (Thin tube vs the wide PCV fitting) Its still installed in reverse, But I'm not sure how you fit it on a Holley since its designed for a smaller opening AFB. Good luck with the gauge issue.
#45
I was pretty sure it was right...if not,the Corvette company I deal with messed up...as far as it all fitting,to be honest,I purchased everything to do the engine compartment,etc,over a 6-8 month period,and by time I had it all together,I had back issues (finally had surgery)..and just couldnt do it myself,so sent car and all the parts to my mechanic who I trust and have used for 20+ years on my company vehicles....he put it all together,and thats how I got it back....it fit,it worked,and although I tried to get everything correct...sure there are a few mistakes.....Hopefully I'll get to the gauge/bubble issue this weekend......will keep the forum and all the guys that helped posted....!
Have a great weekend..
G
#46
And,I'm going to take your suggestions first....before I change any hoses...Your just the first guy who finally LMK that it doesnt matter if hoses are mixed up on the Tee....I thought for sure that was the problem...but now that you say it wont matter,will save that for last....
My plan of action is to boil some water and put gauge sensor in to see if gauge is working correct like another suggested and also do same for theromstat.....then I'll run it thru a couple cycles as you suggested....and park on hill to refill....and take it from there.....
Have a great weekend,
G
#47
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
How old are your radiator hoses? Does you bottom hose have a spring in it to keep it from collapsing? Make sure it is not collapsing as that will cause cooling problems.
#48
Hoses are brand new,as is everything in engine compartment,except the original expansion tank...to be honest,I dont remember if they have a spring in them....I bought from well known Corvette company as exact replacements...but wont hurt to check that also.....looks like I'll be spending a weekend of troubleshooting instead of driving... :-)
Have a great weekend...
G
#49
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,329 Likes
#50
Maybe I am misunderstanding what you're trying to fix. You said early on, you didn't want to drive the car with the gauge fluctuating like that for fear of damaging the engine.
You trying to fix a hot engine or a fluctuating gauge?
#51
What I do know for sure is everything is new,including a hi-flow rad./and water pump....cap/thermo/hoses/...and its not a compression leak....and not losing fluid.....Its never overheated,but you can feel the engine heat more when it happens when driving...so,I'm totally stumped... :-(
George
#52
So,another member sent me a diagram from corvette manual showing TOP hose 3/4" coming from heater on firewall it the one Tee'd off to Expansion tank and then to Water Pump....and the lower hose on firewall is the "smaller (5/8") hose and goes direct to manifold.....Mine is as you say...but according to picture...(think its down below on the thread)..its wrong....so thinking I need to change them around....sounds like that could be the problem,yet I've gotten 3-4 different replies,which makes it confusing.....
Going to take it out today if it stops raining,and run with cap off also...and maybe drill the small hole in thermo flange as some suggested.....checked gauge this morning and its fine....
G
#53
C2 of Year Finalist (performance mods) 2019
[QUOTE=ricoman;1597773352]Hi Mark,
G[/QUOT
The smaller diameter, 5/8, is the return hose and goes to the water pump. It should have the T for the expansion tank. The 3/4 hose off the manifold should go straight to your heater. If your T is in the 3/4 hose it will force coolant out of your expansion tank when you acceralate. Over time your system gets air in the system. When I bought my car 6 years ago it was set up backwards and thanks to JohnZ I got it corrected.
G[/QUOT
ricoman (08-11-2018)
#54
[QUOTE=MarkC;1597773637]
Hi Mark...Yes I think your right...and actually right in the middle of changing it around and going to buy some new hose....I attached a photo....I'm rerouting it exactly as in photo...as far as the actual size hose...maybe he worte wrong sizes on diagram,or you mixed it up....right now,my 3/4" will be the one with the T and running from top of firewall to water pump....and my 5/8" hose will be going direct from lower firewall to intake....correct?? Sure hope so.....if all fitting right,just needed new 3 ft length of 5/8.....I also googled photo of the set up,and it looks right..and actually saw a professional mechanic doing hoses on a Mustang (AHHHHH)....but at end said,this is how it works on ford,chevy..etc....so sure hope this is the end of my problem...
Hi Mark,
G[/QUOT
G[/QUOT
#55
My car has aftermarket air so the heater connections are different. The size hose shouldn’t make a difference. Good luck on fixing the issue.
#56
Just finished it,looks exactly as photo..everything fits right.....but cant take for test drive till tomorrow....its raining again in WA...LOL
Enjoy your weekend....hope driving your Vette...
George
#58
LOL..!!! yeah,but it ALWAYS rains in WA.....I'm from NJ....so use to the weather where you are....\
I really wanted to go for drive tonight...but black clouds and on again off again rain....hopefully tomorrow.....
Thanks for your help and will keep the group posted on my drama....!!
Regards,
George
Regards,
George
#60
Are you sure that your temperature sensor is compatible with your gauge?
I changed the hoses around yesterday,and if the rain stops today,I'll take it out for test.....
Thanks for your reply,
G
