1966 Build sheet
Received 19,223 Likes
'20-'21-'22-'23-'24
Moved to C1/C2 Corvettes.
The only information you can get for the Vin is it's a 66 convertible built appr Apr 6, 1966. Other records weren't kept and no build sheet came with the C2's until 1967 and they were glued to the top of the gas tank. If you have the POP card from the original owner's manual you can get transmission, axle ratio, engine codes, original owner's name. color and interior color. Other than that metal card or an original bill of sale or window sticker you're pretty much out of luck.
