Cold start a C2 (and probably others)
#41
Received 2,128 Likes
2015 C2 of the Year Finalist
Why would you be doing "hole shots" with a cold engine anyway?
Seems like that might be hard on equipment whether you had a choke and/or heated intake?
Lot's of drivers have never had the experience of driving a car without FI, PS, PB, AC, automatic transmission and other features that are now stand equipment on almost all new cars until they buy an old collectible. Even if everything works as designed on an old car, newb drivers tend to think there is something wrong with the car.
I showed the picture to demonstrate that even with long runners, this motor will fire once there is fuel in the bowls and without chokes or heat it is not hard to keep running for the 30 or less seconds it takes for the intakes to be warm enough for a no drama pull away. But pumping and waiting for everything to "coalesce" is important for a smooth start process...one in which bystanders are impressed rather than giggling.
Dan
#42
It was directed at me. The whole point of my comment was that you shouldn’t be dumb azz enuf to do hard launches with a cold engine. So I don’t know that further comments were needed.
#43
I knew a guy once who liked to mat a stone cold motor, said he read an engine is better off warming up as fast as possible. I tried reasoning with him but some dopes need to remain that way.
Dan
#44
Received 1,843 Likes
And yeah, some are dopes enough to do just that. Especially with today's FI cars that will take right off without hesitation.
When you throw a pebble in the water, it's tough for it not to ripple the surface.
I am surprised those long rams aren't very cold natured without a choke to keep them running. Not starting, just running. I was thinking a road test or two back about 1959-1960 reported they were a little cold natured.
#45
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
Further comments needed? Here? This joint wouldn't be what it is without "further comments."
Dan
Dan
Steve
#46
No need to get excited. Wasn't directed at anyone. Just a comment based on another comment.
In 11 years I've never tried to start it below 55 degrees, never had a call to, but I imagine it would be fine as long as I'm not trying to rob a bank. As Frankee said, you have to know how to "feather" it until she will hold an idle & go into reverse without stalling.
Dan
#47
Received 2,330 Likes
Many drivers are completely unaware of the need of warmup at a mildly elevated rpm with older performance engines to warm & seat the rings and expand the more loosely fit forged pistons, to prevent washing gasoline past the cold rings on start up, because new cars are EPA regulated and designed to quickly return to a slow idle for emissions control. The other high idle need in older performance engines is flat tappet and cam lobe oiling, a concern that is resolved with modern roller lifters. Every start up after storage is a new break in start, one that is not as critical to be prolonged in duration as cam break in with a new engine, but more critical with high valve spring forces and the looser clearances than what is typical of modern cars with computer controlled engine management.
Vintage flat tappet engines benefit from a quick start and a mildly elevated idle, 1200 to 1600 rpm, on a cold start up, for the same reasons the practice is required for a new engine break in. Slow cranking of a cold engine, even the practice to build oil pressure, is not advised, when a quick start and mild elevated idle will quickly deliver oil pressure, heat the expansion of critical component metals to quickly build compression, and quickly promote sliding friction on lifter faces. The higher velocity of gasses in and out of the engine also improves fuel mixing and removal of exhaust condensation for cleaner operation and less corrosion. The only caution regarding an elevated idle on start up is to move the vehicle to a well ventilated location because the emissions have considerably more CO than modern a engine's exhaust (roll it outside the garage after the quick start up).
#48
They are as you put it, cold natured. Here's the thing about them, the two top engine options for 60 and 61 Dodge & Plymouth was a 361 or 383 with these rams. (Actually in 61 only the 383 was available with rams but AMA listed the 413 too). So a guy wanting to tow puts one of these in his station wagon and finds every deep cold start an exercise in trauma and frustration. I've run into a few old Mopar mechanics who told me how many they removed and the sound they made hitting the bottom of the trash can. I think the typical station wagon owner of the day, especially if he let it fall out of tune, wouldn't put up with the nonsense. The guys with 300 F's or G's tolerated it given the exhilarating performance, but workaday cars with rams were not for everyone.
Dan
Dan
#50
I don't know where you guys are getting this 30 - 60 seconds and good to go.
I have no choke, the heat riser is blocked, and there is a 1/2" carb spacer. It takes my engine several minutes before I can reliably get under way and my oil won't hit 150 degrees in the first 1/2 - 1 mile of starting.
I live on a hill and exit uphill. But I first run the car down the hill through the cul-de-sac to warm up and avoid any stalling going up the hill.
#51
Where do you read "good to go," without caution and respect for a proper engine & oil warm up before excessive load or rpm (per your example and practice)?
#52
Maybe you guys should consider putting a choke on the carburetor, it's purpose is to eliminate exactly what you are talking about.
The following 2 users liked this post by tbarb:
Factoid (11-02-2018),
Frankie the Fink (09-18-2018)
#53
As MikeM has pointed out a choke won't help with light-off, its purpose is to allow enough fuel in a cold induction system to stay in suspension (while the majority of it condenses into liquid some of which ends up in the crankcase as we know) to allow sustained running. But chokes can stick, bind, wash down cylinder walls and contaminate oil. The electric ones are aesthetically inconvenient. I realize I'm making a whole lot out of nothing and that a properly operating choke is as useful as a soap dish in the shower, maybe more so. I have them on all but 2 cars.
But I don't have a problem letting that chokeless 413 rumble under my feet a little bit before putting her in gear. As for starting cars, I have two rules, nothing is ever started without being brought to operating temperature before stopping, and nothing but gentle, moderate speed driving until engine reaches operating temperature. I've kept 8 engines happy over 20 years.
Dan
#55
I'll play.
Dan
Dan
I am not trying to argue with you, that car you posted a picture of is beautiful. That being said a properly adjusted choke circuit is a very important thing for a street driven car.
I agree that pumping liquid fuel into the engine without a choke will lite it off but the purpose of the choke is to simply allow the A/F mixture to be richer during warm up. Most of us here know the cadence of how to feather the gas pedal with a cold engine. The newer generation, forget it..
#57
The reason the subject of the choke came up is because the OP couldn't get his car to start without excesive cranking of the starter. Then he seemed to imply a sticking choke might be his problem with starting the engine. Then he found out different.
I don't think anyone would argue with your point of the choke enriching the fuel mixture. Just that it's irrelevant to getting the OP's engine started in these circumstances .
#58
Dan,
I certainly was not advocating for abandonment of chokes. My point was more to reiterate what MikeM has said - chokes don't get a car started so much as to allow it to keep running until the intake is warm enough to keep the engine from stalling on lean mixtures. I have the choke disabled on my 63 Impala because of a rotted manifold choke tube and never fixed it because it starts and runs fine without it. I didn't use them on the dual quad ram inducted Plymouth as I didn't want manual choke cables under the hood. That car needs more patience after it starts but certainly doesn't need a choke.
Dan
#59
Not sure what the whole discussion is about....plenty of things were done to make life easier for the drivers of grocery getter cars at every level of experience back in the day. Chokes, one-size-fits-all advance curves, fast idles, etc..
I think we forget our Moms, sisters and decrepit uncles drove these cars everyday and a whole lot of 'em could care less about the mechanicals and air/fuel mixtures. Turn the key and go is what they want and expect..
Many here understand what's going on under the hood and can compensate for things until stability is reached...not the case with everybody.
#60
It's a lost art. My parents, grandparents and others had a spark advance lever on the left side of the steering wheel, a hand throttle on the right side, a choke rod on the right side under dash you had to pull out or the cold engine wouldn't start, and after you got the engine running, you rotated the **** to get the best fuel mixture to run the engine on. Did I mention the hand crank if the battery was too low to start the engine?
I started out on similar equipment as I'm sure many here did. Didn't think anything about it.
