400 Block question
The Stroker you get .........
If you want to spend the money you can do allot . Eagle has a wide variety of cranks strokes, some 350 some 400 Main ......All internally balanced . Good Luck
http://www.competitionproducts.com/Eagle-4340-Forged-Steel-Crankshafts/products/2214/
When i had my shop it was $50 an inch, piece, for Mallory. That was 25 years ago it could easily be $100 a piece now. To convert a stock 400 crank to I eternally balanced would take 5-6 pieces. Not a very good investment. I did do a few that wanted a small balancer for clearance or whatever. They would require 2 pieces. The rear is all together different it would require 3-4 pieces.
Received 3,769 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
On the 400 in the 56, I only had heavy metal added tot he front of counter weight and use an early 327 finned balancer. On the rear, I used a neutral balance 168 teeth flywheel and had metal removed as needed for balance. Worked out real nice.
