[C1] Overheating during warn up then OK
Old 09-18-2018, 01:22 AM
althewiz
althewiz's Avatar
Default Overheating during warn up then OK
On my stock 57 FI Corvette, when I do a cold start, the temperature will go off gauge (greater than 220) over a 5 minute period. When I shut off the car, let it cool down so temp is below 200, then restart, temp stays are 180. I swapped out the thermostat but problem remains. Any ideas?
Old 09-18-2018, 06:17 AM
Crunch527
Crunch527's Avatar
Check the wiring for the gauge and if that looks good then maybe swap the temp sensor on the block.
althewiz (09-19-2018)
Old 09-18-2018, 06:25 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
temp sensor on the block?
Bill
Old 09-18-2018, 07:56 AM
ejboyd5
ejboyd5's Avatar
Perhaps the thermostat is reluctant to open on the first start of the day, but when finally opened will work properly, To ease this problems some folks will drill several small holes in the rim of the thermostat to allow a slight flow of water before the the thermostat itself opens.
Old 09-18-2018, 07:59 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
I would have run it without the thermostat until the issue is identified and then monitor the temp with an I/R temp gun at the T-stat housing...
Really only two things going on with cooling: a) air flow, and, b) water flow....
Your issue is b IMO. However, if a 57 has a fan clutch check that too...
Old 09-18-2018, 08:05 AM
jim lockwood
jim lockwood's Avatar
Received 6,507 Likes on 2,996 Posts
C2 of Year Finalist (track prepared) 2019
I've seen this before. It's almost certainly the thermostat being slow to open. My suggestion is to swap thermostats again, but this time buy a different brand.
Old 09-18-2018, 04:57 PM
bj1k
bj1k's Avatar
Nobody seems to know what is the correct temperature sensor . I have tried several that I was told at different auto parts stores were right and the gauge is still not accurate .
Old 09-18-2018, 05:07 PM
dcamick
Tether Man
Support Corvetteforum!
dcamick's Avatar
Received 2,013 Likes on 1,038 Posts
2019 C1 of Year Finalist (appearance mods)
I agree!!!
Dan Hampton
Dan Hampton's Avatar
Received 1,717 Likes on 803 Posts
2018 C1 of Year Finalist
Good point. Some thermostats are designed that way. In 1972, I purchased a new Datsun 240Z. On start up the temp gauge would swing over to 210 and then relax back to 180. The manual said that if the gauge reading stays at 210, just let it idle until it returns to 180. The curious thing is that when I replaced the thermostat years later with a non OEM, the needle would never rise to that 210 level. In cold weather the car, after the change, never idled very well in temps that were below freezing. There was a method to Nissan's madness.
Old 09-19-2018, 09:36 AM
Robert61
Robert61's Avatar
Received 1,534 Likes on 1,067 Posts
First are you sure you have a spring in the lower hose? Second are you sure it's completely full of water, if it has air locked at the thermostat it may keep it from opening. Third I would remove the thermostat put it in a pot of water and boil it. You know water boils at 212*. You can clearly see if it is functioning correctly. Right before it comes to a full boil you'll see it open.
Old 09-19-2018, 10:26 AM
61X
61X's Avatar
It's been a while but isn't it possible to install those thermostats upside down ?
Old 09-24-2018, 09:15 AM
althewiz
althewiz's Avatar
Apparently, the problem was a slow opening or sticking thermostat. I replaced with a Mr. Gasket Balanced High Performance Thermostat (#4364), Problem solved!
Thanks for all the good advice.
Old 09-24-2018, 09:24 AM
jim lockwood
Is that Thunderhill in your avatar?
Old 09-24-2018, 09:59 AM
althewiz
althewiz's Avatar
Yes, good call! That photo is from one of our early 24hrs of Lemons races at Thunderhill. The car is Tinyvette, a 1971 Opel GT themed as an ALMS Corvette. Ten years later, after some modifications and lots of body work, the car is still competing although I have since retired from my "racing career." The car's latest claim to fame is a double Cannonball Run from Lemons Headquarters in Emeryville,CA, to the Red Ball Garage in Manhattan then to Redondo Beach, CA, two drivers. Started on a Wednesday, finished the following Monday, 6,153 mi.
Oops, Sorry, didn't mean to steal my own thread!
Old 09-24-2018, 10:17 AM
jim lockwood
I think forum rules permit you to hijack your own thread. You probably won't be banned.
Turns 12 and 12A. I've been thru them many times.... maybe as many as 1000 times, now that I think about it.
Your Tinyvette looks too nice to be a Lemons car. Seriously. I've seen some goofy junque at Lemons events.
The fact that your car has piled on so many miles is a tribute to your car prep. Preparation, preparation, preparation.... the three secrets to having fun at the track.
To Overheating during warn up then OK
Quick Reply: [C1] Overheating during warn up then OK
