67 fuel line change help
I have moved my '67 from storage to the shop where I am going to go through it to get it running again. Oh, the storage time was 28 years....
The gas tank was a mess so I have removed it and I am going to replace it. The tank had 4 small holes the size of a dime or smaller on the top of the tank. So I don't want to repair it. And yes, I had fuel in it before I parked it.
Shame on me....
I am now retired and I will attempt to get my car on the road again.
When I took the tank out, I followed the metal fuel line that goes to the front of the car. From the tank it goes into the frame rail for 2 feet or so, exits, and then is attached to the outside of the frame rail to the engine compartment. I have spoken to a few people, mostly Corvette repair businesses, and they say I have to lift the body to change the metal line. I'm not sure if they are looking for more business....
I have heard several horror stories lifting the body off the frame. I'm not sure I want to do that for several of those reasons. I work alone and it would be very difficult for me to build a fixture to lift the frame. If I have to I will, but if the body comes off, then I will want to strip the frame and get it sand blasted and repainted. I am retired, so I want to get the car back on the road and do maintenance as time allows, eventually replacing the carpet, seat covers and having the car painted. This is not going to be a show car, just my hot rod to run around town in.
Has anyone replaced the metal fuel line WITHOUT lifting the body?
Shame on me....
Received 6,939 Likes
2015 C2 of Year Finalist
Why do you think you need to replace the fuel line? If it’s not rusty I wouldn’t worry about. Flush it out and move on. If you really want to replace it I would jack the body off the frame a few inches to gain access to it and replace the body mount bushings at the same time.
Received 3,443 Likes
08redrocket (09-19-2018)
Thanks. I flushed and blew the line out and old gas came out but no rust. I'll use it and see how it goes.
The car sat in my garage all that time. I saw it and touched it every day.... One of those "when I get the time" situations. I have had 3 other new corvettes during that time. The '67 was my first one and I didn't want to sell it. I knew this day would come, so off I go!!
Received 1,534 Likes
If you have not tested the fuel line, I would put 20# of air or water on it to determine if it could have pin holes. A leak down test will give you an idea if there is a leak in the line inside the frame.
At a minimum, I would replace all of the rubber fuel lines after 28 years. They are probably hard and will easily crack.
Just $.02
Ron
The rubber lines are toast. The fuel pump had fuel in it also. I poured the gas out of it but I can't get the lever to move, so I guess the inside of the pump is junk also.
All of the screws that held the filler neck in place broke off when I loosened them. I had sprayed them with penetrating fluid but that didn't help. I pressure tested the metal lines for the fuel and they are OK.
Looks like the tank had been replaced some time ago, before I go the car. The tank paper is not there.
I also took all of the calipers off and will rebuild them and the master cylinder is getting changed out. All of the rubber lines on the car are being replaced, every one of them!
Pictures to follow soon.
Thanks for all of your info and suggestions.
