Give me your opinion on this SWC
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
This is a very nice "pretty" car, but it is not perfect.
I agree with all the previous criticisms.
Someone spent a lot of money on this restoration, but they fell short on many of the small details.
Things like way too much orange paint on the bellhousing but none on the bypass hose.
Also, the battery terminal clamp is right off the shelf at Walmart.
However, what stands out to me the most is the incorrect position of the alternator adjusting brace.
It is hard to tell from the photo, but a correct "numbers matching" T-10 will have a lower drain plug.
So, is $135,000 a fair price for a pretty car?????
Some here will help others spend their money really fast. I’d love for this car to be worth $135k as that would drag the value of all of ours up I think.
But, alas, it is not.
Someone told me a long time ago......
There are only 3 things that matter, the VIN Tag, Trim Tag and Stamp Pad.
Everything else can be fixed.
Is $135,000 a good price for a SWC that needs a lot of things fixed????
IMO at the ASKING price this should be a fuel injected car.
Received 1,044 Likes
C2 of Year Finalist (appearance mods) 2019
When 63 coupe’s completely stripped bodys, with no trim no interior no glass are selling for $70,000 not just asking that money, then $135,000 for a Done car especially if it has the original 340 hp motor is not way out of line. My 63 300 hp cp ex show car, just sold for $145,000
Received 3,443 Likes
I love ya, Frankie, but there is no comparison with a between a '63 SWC and a '61, market-wise. SWC's are hot right now, and hyped. '61's are common and all over the place at all price levels. Apples and Oranges, IMO. I'm betting you wouldn't let your base engine SWC go for south of 100k.....if it were mine, I know I wouldn't!!!!
I won’t keep on about it.
A few months ago I was the guy getting his nads stomped on here for over-valuing split windows.
Now I’m a low-baller.
What a difference a few months make!
Jeffthunbird (09-20-2018)
I don't know ANYTHING about this car or the seller, or if this is even a real ad and not a scam, but a friend just sent me this CL listing: https://newyork.craigslist.org/stn/c...677279307.html
Might be worth an inquiry. Again, caveat emptor and all that fine print stuff.
If this very, very nice looking '63 is in fact #2,248 and shows body #1,055 then I think that there might be something fishy going on. Are you sure that you have the right numbers Eric?
Those numbers do not exactly jive with others that I've recorded including another silver coupe with the same body number.
Take the good advise given and have someone knowledgeable with 63's take a hard look at it.
It may be entirely possible that the tags are correct but best make sure for that kind of hard scratch. Can you post a picture of the vin and trim tags?
#33
2015 C2 of Year Finalist
#34
The OP has 'kicked the tires' in cyberspace on a bunch of split windows at this point.....I'm counting on him to have the good sense to engage a pro to help out when he gets serious.
The split window market is starting to smack of some of the shenanigans going on with midyear big blocks it seems...
#35
#36
Another 340HP car. Sure are a lot of those out there. Pretty car. Don't worry about lack of hood blocks. My car is in the mid 7000 and there are no signs of hood blocks on the inner fender or hood.
#37
I keep waiting for one of these bargain basement 63's that everyone talks about to show up but, as usual, that seems to be elusive or they really need a paint job. A real paint job starts at $20K and then you get into the slippery slope of stainless, chrome, and weatherstripping. I am in serious talk with one forum member for his Red 63 but the car is presently apart and will, in all likelihood, need paint. By the time I buy his car I will save a buck but spend time in the project which probably costs me more in productivity at the office. With that said if the car is as overpriced as several of you say then certainly you want to sell yours for a big profit to Eric "big balance sheet" Lipper. If you don't want to sell yours then I suspect that $120$ - $130K is actually the right money for strong car with a few resolvable warts.
Just my .02
#38
95 is a good price for a 340 car but if you look at the front end of that car you can see the driver side front has been hit and repaired the hood doesn’t fit amd the headlight doesn’t fit makes a big difference in value. that’s only what you can see in the picture. 63 did not have knock off wheels so you’re looking at about $3000 for hubcaps and steel wheels. And they did not have redline tires or hurst shifters.
#39
Wrong radiator, it’s very hard to tell from pictures but the color seems to be off some. Daytona blue is a very hard Color to redo. It’s hard to tell from this angle underneath but it appears as though it’s a Muncie transmission it should be a Borg Warner T10. Something you should check.
