63 repro distributor tag
Old 09-24-2018, 10:19 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Default 63 repro distributor tag
Who makes a decent one ? Mine has the metal tang securing the end broken off. It’s zip-tied onto the distributor for now.
Old 09-24-2018, 10:52 AM
vettebuyer6369
vettebuyer6369's Avatar
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes on 2,775 Posts
Last one I custom ordered was from Paragon, part #8150.
Frankie the Fink (09-24-2018)
Old 09-24-2018, 11:55 AM
Rich Yanulis
Rich Yanulis's Avatar
Why don't you thoroughly clean everything, put some clear JB Weld behind it.......and be done.
If it doesn't hold you can always get a repro tag.
emccomas
Support Corvetteforum!
emccomas's Avatar
Received 1,283 Likes on 732 Posts
Have you checked for a good used original. Your distributor is not a rare one as I recall, so one of the used parts suppliers may have one with the correct part number and date code to match what you have now.
Two possible suppliers (and I am not making a recommendation) is Jim Clemens in Florida, and Chicago Corvette. Both hare offered distributor tags in the past via Ebay.
Old 09-24-2018, 12:00 PM
Frankie the Fink
Army
I'm pretty sure that tag is already a repro put in place during the Lars rebuild....so I'm not all fizzed up to preserve it....
Rich - JB-Weld ? From you ? I now expect a meteor to strike the earth...
Old 09-24-2018, 12:06 PM
Rich Yanulis
5 minutes and you're done.......
But, I made the comment assuming that you would be preserving your ORIGINAL tag.
Old 09-24-2018, 12:27 PM
Frankie the Fink
Army
Order placed at Paragon - thanks Steve..
Old 09-24-2018, 01:28 PM
vettebuyer6369
Old 09-24-2018, 02:03 PM
MOXIE62
MOXIE62's Avatar
If you would, post a picture of it when you get it. The date on my tag is meshed in from the hold down clamp being pushed against it.
Old 09-24-2018, 02:32 PM
pop23235
pop23235's Avatar
Received 1,023 Likes on 683 Posts
Same problem here. I’ve several original dist. and removing them to clean and restore, about 1 in 4 won’t break. The one breaks when you reinstall!
Old 09-24-2018, 02:47 PM
Frankie the Fink
Army
OK.... The dang things are flimsy -- especially where they are bent to strap them on the distributor...
To 63 repro distributor tag
Quick Reply: 63 repro distributor tag
