[C2] Functional cowl induction on my 1964
Received 5,543 Likes
Soon this will be functional! The plenum is bonded in nicely and trimmed. I built a wooden plug to hold the fiberglass cloth in place on the front edge where I had to fill gaps. Tomorrow I’ll bond the two pieces together and fill and smooth the small gaps and voids. So far it’s going great!
Nice. Quick question. Are your rear fenders flares out just a hair or are your rims set in a little? Maybe it’s just the picture angle. The reason I ask is because talking with the painter today he said he could do about a 1” overall flare that looks good to help with wider tires.
elwood13 (10-09-2018)
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Nice work.
Factoid (10-09-2018)
Interesting project. Great job!
Factoid (10-10-2018)
And she’s 99% done! I sanded and sanded and sanded and now I can’t use my thumb print to log on as the print no longer exists. I painted it with SEM flat trim before lunch and bolted the hood back on to the paint can finish drying. Tomorrow morning I’ll align the hood, check the clearance between the seal and hood, and install the air cleaner. I should be ready for C&C on Saturday.
St. Jude Donor '07
Bill
Factoid (10-11-2018)
Very nice.
Looks KILLER! I have a few questions about it now that its done. What's the distance from the air cleaner base from the underside of the hood? Basically looking to see what the stack height is. That chamber is a lot bigger than I thought it was, and I'm not sure I's have the room to duplicate this on my car. What intake are you using, and what motor mounts?
https://www.speedwaymotors.com/World...fold,8599.html
Stock motor mounts. The gap between the plenum lip and the underside of the hood is 3 1/2” front and back and 3” left and right. The drop base is dropped about 2” as you can see in the picture below.
It’s actually just less than 2” as the mounting flange is below the high point shown by the tape measure.
All done, works great! The engine sounds awesome! Hard to believe it makes that much difference, but with the intake now facing the driver the sound is intoxicating. I’ll make a video this weekend. I’m also going to make a grill to keep small birds, rodents, and Ford Mustangs from getting sucked into the intake.
USMC 0802 (10-12-2018)
#33
Factoid (10-12-2018)
#35
lol, I’m actually trying to remove the billet bling and achieve a more old school look. My biggest challenge is the brake booster interferes with the driver side valve cover requiring a clearanced valve cover like the big block, but no one makes a small block version.
#36
Great project, which I'd like to do on my '65. Is that plenum a kit you bought? I know they think originals are made of gold !
Unfortunately, all the pics are very blurry and fuzzy, so I can't see them clearly on my iPad. Even when I click on them to view closer, they appear to have the resolution digitally reduced.
Must have a setting wrong or something.
Anyone have an idea that might help me ?
Edit: viewed pics on my PC, but would still like to get my iPad correct.
#37
I made a short video. If it would ever stop raining I could do a better job. If I really had my ***** together I would have done a before and after, but I’m not that fancy. I will say it sounds better, but then it could just be me wanting it to sound better!
Oh, I made a grill and then calculated that it would reduce air flow by about 30%, so it’s out.
#38
https://youtu.be/ADTRX-X_UzM
#39
https://www.ecklerscorvette.com/cata...&q=L88&x=0&y=0
Fitting the air box to the hood is not for the feint of heart! All the best!
White Monster (10-14-2018)
#40
Your bonding of the unit looks clean! How did you do it?
Adhesive? A single layer of glass? Etc?
