C2 on a C3 frame
C2 on a C3 frame
I have a 64 coupe that needs a frame, I have a bare 69 frame
that is decent, could I use that frame on my 64, beside different
body mounts is it doable.I am a pretty good welder
Received 6,929 Likes
2015 C2 of Year Finalist
If you have both side by side it would be doable there should be write ups on here on what’s all different and what needs to be changed
LT-1 kid (09-30-2018)
If your frame has the braces as shown you will have to remove them or modify the body.
Also, C3 fuel lines ran along the bottom of the frame rail so you may have to modify the body if you go that route. You won't have the notch in the body for the line.
I can use the rear frame section at the fuel tank area, and was planning to run the fuel lines as stock for a 64 or slightly modified
Slalomfiend used a 75 for his 67. Here is a link to his build and it is a beautiful car. He did a great job.
https://www.corvetteforum.com/forums...ct-update.html
Received 1,044 Likes
C2 of Year Finalist (appearance mods) 2019
If your car is not close to original it won’t make much difference but There are so many differences in a 68 and up frame that a not so well trained eye could spot it in a minute hurting the value of your car. (Don’t say anything 64 haters) with so many resto mods being built there are a lot of 64 frames for sale at a good price. I sold a nice roller for 2k.
