[C2] Transmission Tunnel Clearance
Just did the body drop on the 64 convertible and have noticed the 1-2 shift lever in the tunnel is either touching the tunnel and insulator or so close it will in operation. No difference in side to side clearance with body/frame. What else should I check?
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
I had to scoot the body with the bolts loose in the captured nuts on the frame to get the alignment I needed on my 63. can you move it ever so slightly towards the DS?
I assume you know the driveline is not perfectly straight along the center axis. I know you prob already are aware but thought I’d mention it.
pop23235 (10-19-2018)
Does it hit in both 1st and 2nd? if not, it’s just shifter adjustment. If it’s both, make sure you have the shift arms correctly installed (1-2 lever on 3-4, for example). You should have plenty of room.
Harry
Harry
Of course I'm going to say it's correct, but doing a body off and it hasn't been driven, so.... It seems to shift. There is only one way (that I know of) to assemble the shifter. 1-2 sticks out to the left, 3-4 in the center, slightly left, and R on the right almost centered - all looking from the rear. I think this is actually a 65 shifter and rods in a 64, should not be a big deal, but I have the 64 rods and shifter soon from the chrome shop. The shifter appears to be almost identical - allowing for the missing alignment slot on the 64. Never got the argument settled about whether the 1-2 clevis goes to the front lever or the rear hand lever though. Best I can tell, the clevis was on the hand lever in 64 and front trans lever in 65. Don't recall which way I installed it, but these cars and these parts are so similar don't see that being a difference.
